I am trying to convert my training dataset from KITTI to TFRecords using the tlt-dataset-convert
tool and I am getting the following error:
$ tlt-dataset-convert -d tfrecords_kitti_train.txt -o tfrecords/kitti_trainval/kitti_trainval
File "/usr/local/bin/tlt-dataset-convert", line 6, in <module>
from iva.detectnet_v2.scripts.dataset_convert import main
File "./detectnet_v2/scripts/dataset_convert.py", line 14, in <module>
File "./detectnet_v2/dataio/build_converter.py", line 13, in <module>
File "./detectnet_v2/dataio/kitti_converter_lib.py", line 16, in <module>
File "/usr/local/lib/python2.7/dist-packages/tensorflow/__init__.py", line 24, in <module>
from tensorflow.python import pywrap_tensorflow # pylint: disable=unused-import
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/__init__.py", line 49, in <module>
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/pywrap_tensorflow.py", line 74, in <module>
raise ImportError(msg)
ImportError: Traceback (most recent call last):
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/pywrap_tensorflow.py", line 58, in <module>
from tensorflow.python.pywrap_tensorflow_internal import *
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/pywrap_tensorflow_internal.py", line 28, in <module>
_pywrap_tensorflow_internal = swig_import_helper()
File "/usr/local/lib/python2.7/dist-packages/tensorflow/python/pywrap_tensorflow_internal.py", line 24, in swig_import_helper
_mod = imp.load_module('_pywrap_tensorflow_internal', fp, pathname, description)
ImportError: /usr/lib/x86_64-linux-gnu/libcuda.so.1: file too short
Failed to load the native TensorFlow runtime.
See https://www.tensorflow.org/install/errors
Can anyone suggest what may be causing this issue and/or how to solve or work around it? Thanks in advance…
