I’m trying to test my Dataset, I had converted it in Kitti format but when I run the notebook: detectnet_v2.ipynb
It shows the following error when running the command (point B of the notebook):
“# Creating a new directory for the output tfrecords dump.
print(“Converting Tfrecords for kitti trainval dataset”)
!tlt-dataset-convert -d tlt_specs/detectnet_v2_tfrecords_kitti_trainval.txt
-o train/tfrecords/kitti_trainval/kitti_trainval”
it returns:
2021-04-08 20:51:20.406096: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
Using TensorFlow backend.
File “/usr/local/bin/tlt-dataset-convert”, line 5, in
from iva.detectnet_v2.scripts.dataset_convert import main
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/dataset_convert.py”, line 14, in
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataio/build_converter.py”, line 13, in
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataio/kitti_converter_lib.py”, line 21, in
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataio/dataset_converter_lib.py”, line 19, in
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataloader/utilities.py”, line 16, in
File “/usr/local/lib/python3.6/dist-packages/modulus/init.py”, line 8, in
from modulus import blocks
File “/usr/local/lib/python3.6/dist-packages/modulus/blocks/init.py”, line 22, in
from modulus.blocks import data_loaders
File “/usr/local/lib/python3.6/dist-packages/modulus/blocks/data_loaders/init.py”, line 9, in
from modulus.blocks.data_loaders.sqlite_dataloader import SQLiteDataLoader
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/blocks/data_loaders/sqlite_dataloader.py”, line 10, in
File “/usr/local/lib/python3.6/dist-packages/modulus/dataloader/init.py”, line 9, in
from modulus.dataloader import humanloop
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/dataloader/humanloop.py”, line 16, in
File “/usr/local/lib/python3.6/dist-packages/modulus/processors/init.py”, line 26, in
from modulus.processors.buffers import NamedTupleStagingArea
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/processors/buffers.py”, line 11, in
File “/usr/local/lib/python3.6/dist-packages/modulus/hooks/init.py”, line 9, in
from modulus.hooks.hooks import (
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/hooks/hooks.py”, line 25, in
ModuleNotFoundError: No module named ‘nvml’
Can someone help me with this issue? I don’t have any idea
Thanks in advance
