I want to play mp3 files using usb soundcard
hello.
My development environment is as follows.
Hardware Platform: Jetson nano
DeepStream Version: 5.0.1
JetPack Version: 4.4.1
I want to play mp3 files in deepstream_app.c using usb soundcard as below.
Can I play mp3 files without installing a separate driver?
If possible, can you provide a reference material or simple sample?
By default deepstream-app is video only. You would need to check the source code and implement the audio part.
You can try to play mp3 in gst-launch-1.0 first. May refer to this command:
