It’s set up like this.
type: ds3d::datafilter
link_to: ds3d_sensor_fusion_render
in_caps: ds3d/datamap
out_caps: ds3d/datamap
custom_lib_path: libnvds_tritoninferfilter.so
custom_create_function: createLidarInferenceFilter
config_body:
in_streams: [lidar]
mem_pool_size: 20
#datatype: FP32, FP16, INT8, INT32, INT16, UINT8, UINT16, UINT32, FP64, INT64, UINT64, BYTES, BOOL
model_inputs:
- name: images
datatype: FP16
shape: [4, 3, 864, 1536]
- name: feats
datatype: FP16
shape: [4, 8000, 10, 9]
- name: coords
datatype: INT32
shape: [4, 8000, 4]
- name: N
datatype: INT32
shape: [4, 1]
- name: intervals
datatype: INT32
shape: [4, 10499, 3]
- name: geometry
datatype: INT32
shape: [4, 1086935]
- name: num_intervals
datatype: INT32
shape: [4, 1]
gpu_id: 0
#input tensor memory type after preprocess: GpuCuda, CpuCuda
input_tensor_mem_type: GpuCuda
custom_preprocess_lib_path: /opt/nvidia/deepstream/deepstream/lib/libnvds_3d_v2x_infer_custom_preprocess.so
custom_preprocess_func_name: CreateInferServerCustomPreprocess
preprocess:
intervalsFrom: /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-3d-lidar-sensor-fusion/v2xfusion/example-data/intervals.tensor
geometrysFrom: /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-3d-lidar-sensor-fusion/v2xfusion/example-data/geometrys.tensor
imagesFrom: DS3D::VideoPreprocessTensor+0
featsFrom: DS3D::LidarFeatureTensor+1
coordsFrom: DS3D::LidarCoordTensor+1
NFrom: DS3D::LidarPointNumTensor+1
postprocess:
score_threshold: 0.5
batchSize: 1
labels:
- car:
color: [255, 158, 0]
- truck:
color: [255, 99, 71]
- construction_vehicle:
color: [233, 150, 70]
- bus:
color: [255, 69, 0]
- trailer:
color: [255, 140, 0]
- barrier:
color: [112, 128, 144]
- motorcycle:
color: [255, 61, 99]
- bicycle:
color: [220, 20, 60]
- pedestrian:
color: [0, 0, 230]
- traffic_cone:
color: [47, 79, 79]
config_file: /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-3d-lidar-sensor-fusion/v2xfusion/config/triton_mode_CAPI.txt
type: ds3d::datarender
with_queue: sink
custom_lib_path: libnvds_3d_gles_ensemble_render.so
custom_create_function: NvDs3D_CreateGlesEnsembleRender
gst_properties:
sync: True
async: False
drop: False
config_body:
# window size
window_width: 1920
window_height: 540
color_clear: true
window_title: DS3D-Lidar-V2X-Fusion-dGPU
render_graph:
# cam_0:
- texture3d_render:
layout: [0, 0, 960, 540]
max_vertex_num: 6
color_clear: false
texture_frame_key: DS3D::ColorFrame_0+0
- lidar3d_render:
color_clear: false
lidar_color: [0, 0, 255]
# original lidar data key
lidar_data_key: DS3D::LidarXYZI_0+1
lidar_bbox_key: DS3D::Lidar3DBboxRawData_0
enable_label: True
element_size: 4
# project lidar data into image require image size settings
project_lidar_to_image: true
image_width: 1920
image_height: 1080
intrinsics_mat_key: DS3D::Cam0_IntrinsicMatrix
extrinsics_mat_key: DS3D::LidarToCam0_ExtrinsicMatrix
z_range: [-300, 300]
x_range: [-1000, 1600]
y_range: [-1000, 1600]
line_width: 2.0
font_size: 20
#y_range: [-100, 100]
# lidar top view
- lidar3d_render:
# layout [x0, y0, x1, y1]
layout: [960, 0, 1920, 540]
view_position: [20, 70, 10]
view_target: [30, 10, 10]
view_up: [1, 0, 0]
perspective_near: 0.3
perspective_far: 100
# angle degree
perspective_fov: 60
# 0 stands for (layout.x1 - layout.x0) / (layout.y1 - layout.y0))
perspective_ratio: 0.0
lidar_color: [0, 255, 0]
# lidar transformed to camera coordinates data key
#lidar_data_key: DS3D::LidarAlignedXYZIKey
element_size: 4
color_clear: false
