I would like to build the OpenCV with CUDA on Orin Nano
I would like to build the OpenCV with CUDA on Orin Nano, but I am unable to build it because it fails to link CUDA related.
Orin Nano installed JetPack 6.1, then installed cmake and built OpenCV.
We built OpenCV based on the following link.
OpenCV on Orin Nano
sudo cmake -D OPENCV_EXTRA_MODULES_PATH=../../opencv_contrib/modules -D WITH_CUDA=ON -D CMAKE_BUILD_TYPE=RELEASE -D CUDA_ARCH_BIN=8.7 -D CUDA_TOOLKIT_ROOT_DIR=/usr/local/cuda ..
When the above command is executed, the error message “CMake Generate step failed. Build files cannot be regenerated correctly".
Error
    linked by target "opencv_videostab" in directory /BuildOpenCV/opencv_contrib/modules/videostab
    linked by target "opencv_annotation" in directory /BuildOpenCV/opencv/apps/annotation
    linked by target "opencv_visualisation" in directory /BuildOpenCV/opencv/apps/visualisation
    linked by target "opencv_interactive-calibration" in directory /BuildOpenCV/opencv/apps/interactive-calibration
    linked by target "opencv_version" in directory /BuildOpenCV/opencv/apps/version
    linked by target "opencv_model_diagnostics" in directory /BuildOpenCV/opencv/apps/model-diagnostics
-- Generating done
CMake Generate step failed.  Build files cannot be regenerated correctly.
Environment
JetPack: 6.1
OpenCV: 4.5.4 (I tried OpenCV ver.4.8.0 and 4.11.0, same error!)
CUDA: 12.6
Could you tell me the cause?
Please try the script:
Jetson AGX Orin FAQ
Thank you for your response.
I have run install_opencv4.10.0_Jetpack6.1.sh but with the same error. Below is part of the error.
    linked by target "opencv_videostab" in directory /BuildOpenCV/workspace/opencv_contrib-4.10.0/modules/videostab
    linked by target "opencv_annotation" in directory /BuildOpenCV/workspace/opencv-4.10.0/apps/annotation
    linked by target "opencv_visualisation" in directory /BuildOpenCV/workspace/opencv-4.10.0/apps/visualisation
    linked by target "opencv_interactive-calibration" in directory /BuildOpenCV/workspace/opencv-4.10.0/apps/interactive-calibration
    linked by target "opencv_version" in directory /BuildOpenCV/workspace/opencv-4.10.0/apps/version
    linked by target "opencv_model_diagnostics" in directory /BuildOpenCV/workspace/opencv-4.10.0/apps/model-diagnostics
-- Generating done
The environment variable PATH is set to “/usr/local/cuda” and LD_LIBRARY_PATH to “/usr/local/cuda/lib64”.
Are there any other settings needed?
We don’t hit the error on Orin Nano developer kit. Do you use developer kit?
It looks like you create a workspace under /BuildOpenCV/.
In case this is related to write permission, could you run the script under ${HOME}?
So it will create the workspace under the ${HOME}/workspace folder.
I use Orin Nano developer kit.
I had installed JetPack 6.1, but when I reinstalled it with the following command and then ran “install_opencv4.10.0_Jetpack6.1.sh”, it succeeded. Maybe something related to CUDA was missing.
sudo apt-get update
sudo apt-get install nvidia-jetpack
Resolved. Thank you very much.
We had removed some of the error paths to be listed here.
