ib_ep.c:297  MXM  ERROR failed to create address handle: Cannot allocate memory
Hello all;
I keep getting this MXM ERROR. Are there any MXM settings to fix this or get more information. Currently memlock is set to unlimited. Any help on this issue would be much appreciated.
[examples]$ mpirun ./cpi
Process 0 of 4 is on compute-0-21.local
Process 3 of 4 is on compute-0-22.local
Process 1 of 4 is on compute-0-21.local
Process 2 of 4 is on compute-0-21.local
libibverbs: ibv_create_ah failed to get output IF
[1418721136.681747] [compute-0-22:30331:0] ib_ep.c:297 MXM ERROR failed to create address handle: Cannot allocate memory
[1418721136.681200] [compute-0-21:31377:0] ib_ep.c:297 MXM ERROR failed to create address handle: Cannot allocate memory
Environment
Mellanox ofed 1.2
Redhat 6.6
Software version mpich version 3.2a2 or OpenMpi 1.8.4 rc1
[jebaluno@compute-0-21 examples]$ ibv_devinfo
hca_id: mlx4_0
transport: InfiniBand (0)
fw_ver: 2.32.5100
node_guid: f452:1403:0015:6bb0
sys_image_guid: f452:1403:0015:6bb3
vendor_id: 0x02c9
vendor_part_id: 4099
hw_ver: 0x1
board_id: MT_1090120019
phys_port_cnt: 2
port: 1
state: PORT_ACTIVE (4)
max_mtu: 4096 (5)
active_mtu: 1024 (3)
sm_lid: 0
port_lid: 0
port_lmc: 0x00
link_layer: Ethernet
port: 2
state: PORT_DOWN (1)
max_mtu: 4096 (5)
active_mtu: 4096 (5)
sm_lid: 0
port_lid: 0
port_lmc: 0x00
link_layer: InfiniBand
Enable IPv6 support on the hosts by running command:
echo 0 > /proc/sys/net/ipv6/conf/enp131s0/disable_ipv6
Could you open a support case?
The support team will follow up from there.
Thanks,
Ophir.
Opir, does MXM work with ROCE? Our setup at University of Houston is ROCE. I beginning to suspect that MXM is strictly meant for infiniband protocol, any taughts before I formerly engage the support Team.
-Jerry Ebalunode
ipv6 is already enabled for the hosts.
Please, e-mail me and let’s continue via e-mail.
MXM use VERBS in order to transfer packets over Ethernet.
hi alkx, i have met the same problem , how can i contact u
