libi40iw-i40iw_upost_send: post work request failed, invalid opcode: 0x3
hello
running an mpi test on ib Fails.
host is hpe xl230 redhatel 7.5 mlx5 . ibstat ibping is successful. Limits memlock are unlimited
any ideas?
thanks a lot
Markus Bentele
starccm+ -licpath 1716@flexlmhpc mailto:1716@flexlmhpc -mpi platform -fabricverbose -mppflags “-v -prot -e MPI_IC_ORDER=ibv -affopt=v” -on fnx601:4 -server -rsh “ssh -x”
Parsing application description…
Identifying hosts…
Spawning processes…
Process Map:
Process on host: fnx601
rank 0
rank 1
rank 2
rank 3
Process Map End.
Starting STAR-CCM+ parallel server
Process layout for world 0 is as follows:
mpirun: proc 3259
daemon proc 3262 on host 10.96.75.63
rank 0: proc 3887
rank 1: proc 3876
rank 2: proc 3893
rank 3: proc 3892
starccm+: Rank 0:1: MPI_Init: ibv_post_send() failed
starccm+: Rank 0:0: MPI_Init: ibv_post_send() failed
starccm+: Rank 0:1: MPI_Init: ibv_ring_sync() failed
starccm+: Rank 0:0: MPI_Init: ibv_ring_sync() failed
starccm+: Rank 0:1: MPI_Init: Internal Error: Processes cannot connect to rdma device
starccm+: Rank 0:0: MPI_Init: Internal Error: Processes cannot connect to rdma device
Hi Markus,
Thank you for posting your question on the Mellanox Community.
Based on the information provided, the issue occurs on the Intel Ethernet card and not on the Mellanox ConnectX-4/5 (mlx5) card.
For this issue, you need to contact Intel as they are the maintainer of the card and i40iw verbs.
Thanks and regards,
~Mellanox Technical Support
