the program below gives the following message using PGI CE 17.10:
$ pgfortran vectorspace_function.f90
PGF90-F-0000-Internal compiler error. insert_sym: bad hash 755 (vectorspace_
function.f90: 96)
PGF90/x86-64 Windows 17.10-0: compilation aborted
The program (I have not tried to shorten it, but it is only 221 lines):
! vectorspace_function.f90 --
! Define a module for dealing with vector spaces in an abstract sense
! and a specific class for adding and multiplying functions.
! The basic data type is an abstract vector, with the following
! operations:
! "+" - to add two vectors to get a new vector
! "*" - to multiply a vector with a scalar
! We can use an array of vectors as a collection: the operation ".in."
! determines if a given vector is in that collection.
! Note:
! The multiplication does not work as I want, because I need a PASS attribute
! and that conflicts with some restriction.
module vectorspaces
implicit none
type, abstract :: vector
contains
private
procedure(addition), deferred :: add
! This does not work, for some reason:
procedure(multiplication), deferred, pass(b) :: multiply ! Note the "pass(b)" attribute!
procedure(membership), deferred :: is_member
generic, public :: operator(+) => add
generic, public :: operator(*) => multiply
generic, public :: operator(.in.) => is_member
end type vector
abstract interface
function addition( a, b )
import :: vector
class(vector), intent(in), target :: a, b !<= We need the target attribute here
class(vector), allocatable :: addition
end function addition
function multiplication( a, b )
import :: vector
real, intent(in) :: a
class(vector), intent(in), target :: b
class(vector), allocatable :: multiplication
end function multiplication
function membership( a, b )
import :: vector
class(vector), intent(in) :: a
class(vector), intent(in), dimension(:) :: b
logical :: membership
end function membership
end interface
end module vectorspaces
! Test this with an actual implementation
module vectors_function
use vectorspaces
type, extends(vector) :: vector_function
real :: factor = 0.0
procedure(f_of_x), nopass, pointer :: f => null()
type(vector_function), pointer :: v1 => null()
type(vector_function), pointer :: v2 => null()
contains
procedure :: add => add_functions
procedure, pass(b) :: multiply => multiply_function !<== Note: pass(b) required!
procedure :: is_member => is_member_dummy
procedure :: eval => eval_function
end type
interface assignment(=)
module procedure assign_vector_function
end interface
interface
real function f_of_x( x )
real, intent(in) :: x
end function f_of_x
end interface
contains
function add_functions( a, b )
class(vector_function), intent(in), target :: a
class(vector), allocatable :: add_functions
allocate( add_functions, mold = a )
! Clumsy, but that is a consequence of the strict typing in Fortran
select type (add_functions)
type is (vector_function)
select type (b)
add_functions%v1 => a
add_functions%v2 => b
class default
add_functions%v1 => null()
add_functions%v2 => null()
end select
end select
end function add_functions
function multiply_function( a, b )
class(vector_function), intent(in), target :: b
class(vector), allocatable :: multiply_function
allocate( multiply_function, mold = b )
select type (multiply_function)
multiply_function%factor = a
multiply_function%v1 => b
multiply_function%v2 => null()
end select
end function multiply_function
! Dummy - it is possible in principle, but you will have to descend the
! tree of vectors
logical function is_member_dummy( a, b )
class(vector_function), intent(in) :: a
is_member_dummy = .false.
end function is_member_dummy
! eval_function --
! To evaluate the composite function for a particular value of x
recursive real function eval_function( a, x )
real :: x
if ( associated(a%v2) ) then
eval_function = a%v1%eval(x) + a%v2%eval(x)
elseif ( associated(a%v1) ) then
eval_function = a%factor * a%v1%eval(x)
else if ( associated(a%f) ) then
eval_function = a%f(x)
else
eval_function = 0.0
endif
end function eval_function
! assign_vector_function --
! Overcome the discrepancy between vector and vector_function
! Note:
! This is a rather naive implementation - we should actually
! so a deep copy to make it robust.
subroutine assign_vector_function( a, b )
class(vector_function), intent(out) :: a
class(vector), intent(in) :: b
select type ( b )
a%factor = b%factor
a%v1 => b%v1
a%v2 => b%v2
class default
a%factor = 0.0
a%v1 => null()
a%v2 => null()
end select
end subroutine assign_vector_function
subroutine setfunc( a, f )
class(vector_function), intent(inout) :: a
procedure(f_of_x), pointer :: f
a%f => f
end subroutine setfunc
end module vectors_function
! Test program for the vector space modules
program test_space
use vectors_function
implicit none
type(vector_function) :: a, b, c, d
! A bit roundabout, but gfortran at least claims f to be private
f => sine; call setfunc( a, f )
f => cosine; call setfunc( b, f )
! On the other hand: the code is accepted by Intel Fortran
!a%f => sine
!b%f => cosine
c = a + b
d = 10.0 * c
write(*,*) 'a at x = 1.0: ', a%eval(1.0)
write(*,*) 'b at x = 1.0: ', b%eval(1.0)
write(*,*) 'c at x = 1.0: ', c%eval(1.0)
write(*,*) 'd at x = 1.0: ', d%eval(1.0)
contains
real function sine( x )
sine = sin(x)
end function sine
real function cosine( x )
cosine = cos(x)
end function cosine
end program test_space
