The 418.56 release added an experimental environment variable, __GL_ExperimentalPerfStrategy=1, which adjusts how GPU clock boosts are handled. When enabled, this option allows the driver to more aggressively drop the GPU back to lower clocks after they are boosted by application activity. If you are experiencing issues with GPU clock boosting, please try this option and let us know whether or not it helps.
GK208M using prime and stuff, I didn’t notice any difference, still takes about 35sec to throttle down at 0~3% GPU usage.
Where did you set it? I’d recommend putting it somewhere like /etc/profile and then logging out and back in so that it applies to everything.
echo "export __GL_ExperimentalPerfStrategy=1" >> /etc/profile
I’ve set it in the general system environment, so it applies to everybody and everything equivalent to /etc/profile (which is a bash script in gentoo composing the env).
#export
gives
declare -x __GL_ExperimentalPerfStrategy=“1”
as any user.
Repeated on a GT1030, no change either. Driver (of course) 418.56, Xserver 1.20.3, kernels 4.19/4.9, Gnome 3.30/3.28
Tried it, unfortunately no change here… Still takes more than 30 seconds to go back to idle. I put the env variable into /etc/profile, using 418.56 (gtx 1070) and up to date Debian Stretch.
No change here either; I’m using OpenGL compositor, so it thinks that I’m gaming all the time and keeps GPU running on full speed without ever going down.
THAT might be the cause
I’m currently using compositing via xfwm4 (not sure if opengl is used) and it close to all the time can clock down really quickly even when switching through apps, heavy gnome-terminal scrolling and using chromium (site browsing)
We verified this variable internally:
On Ubuntu 16.10 with GeForce GTX 1060 6GB followed by exporting below variable in /etc/profile file.
echo “export __GL_ExperimentalPerfStrategy=1” >> /etc/profile
root@oemqa-Precision-WorkStation-T7500:~# echo $__GL_ExperimentalPerfStrategy
1
root@oemqa-Precision-WorkStation-T7500:~# env |grep GL
I am not able to repro issue and observe ramp down from high to low gpu clock speeds in around 13 to 15 seconds.
I tested it for opening/closing chrome browser and OpenGL applications like glxgears.
Moreover, I observed that few end users are exporting variable as shown below where I am also able to repro issue and ramping down takes 35 to 40 secs.
declare __GL_ExperimentalPerfStrategy=1
I added
to /etc/profile , logged out and in again
but it doesn’t turn up in
env | grep GL
output, probably needs a reboot in between
in any case it jumped to P0 during launch of chromium (compiz used as compositor)
and even during youtube video playback, app switching, browsing, etc. it stays at P8 (GTX 1070)
(so the default behavior already matches your descriptions for me (?), it took around 17 seconds to low frequencies, close to 20s to get to P8 on initial spike)
tested the duration yesterday and it took longer than 27 seconds to clock down
My results: 36 seconds from P0 to P8. That’s as bad as it’s always been.
$ set | grep __GL
exported system-wide in Fedora 29 (mind that this script does not get applied to the X server itself):
$ cat /etc/profile.d/nvidia.sh
$ tr '
$ tr ‘\0’ ‘\n’ < /proc/pidof Xorg/environ
LANG=en_US.UTF-8
DISPLAY=:0
INVOCATION_ID=$RANDOM_HEX_STRING
PWD=/
JOURNAL_STREAM=X:YYYY
SHLVL=0
XAUTHORITY=/var/run/lxdm/lxdm-:0.auth
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
' '\n' < /proc/`pidof Xorg`/environ
LANG=en_US.UTF-8
DISPLAY=:0
PWD=/
SHLVL=0
The CPU takes less than 0.1sec to switch power modes. I wonder why it’s so freaking difficult for NVIDIA to get it right.
Aaron, this must not be a environment variable, this must be a kernel module option. Variables are quite difficult to keep track of from the kernel space.
It must take less than three seconds to switch from P0 to P8 and vice versa. Otherwise you’re wasting our time, power and batteries.
sandipt, the line "declare -x __GL_ExperimentalPerfStrategy=“1"” is just the output when running
export
I can assure you that this variable is set using
in my system environment.
Furthermore, ‘declare -x’ is equivalent to ‘export’.
Further tests I’ve done with the env variable set:
run on plain Xserver: no effect
nvidia-drm.modeset=0/1: no effect
I wrote a small code below to check the environment variable is really used by 418.56.
// inject.c
#define _GNU_SOURCE
#include <dlfcn.h>
#include <stdio.h>
typedef char * (*real_getenv_t)(const char*);
real_getenv_t func = 0;
char* getenv (const char* name)
if (!func)
func = (real_getenv_t)dlsym(RTLD_NEXT, "getenv");
char *val = func(name);
printf("getenv(%s) -> %s\n",name, val);
return val;
And ran the commands:
$ gcc -shared -fPIC -o inject.so inject.c
$ LD_PRELOAD=./inject.so glxgears
From my observation, not only __GL_ExperimentalPerfStrategy but OGL_ExperimentalPerfStrategy seem to be checked by the 418.56 libraries. But, it doesn’t help unfortunately.
Yeah that’s how it works on windows, only takes a few seconds to go back to idle…
I’ve played a little with my settings yesterday and noticed that ForceCompositionPipeline=On, and ForceFullCompositionPipeline=On in xorg.conf has a huge impact on how the driver manages gpu clocks. Without these settings I have to try hard to even make the gpu clock go up (by moving windows, scrolling browser content etc…), but even if it goes up, it usually takes around 15-20 seconds to go back to idle again. Unfortunately I need these settings to eliminate tearing in xfce.
edit: after a bit more testing I can confirm that the driver behaves fine without the options mentioned above. But now I have horrible screen tearing, great…
Yeah, ForceFullCompositionPipeline is pretty much mandatory if you’re not using a compositing window manager.
Aaron,
Please consider those of us who are running with
Option "metamodes" "nvidia-auto-select +0+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}"
On the GT1030, I’m running without an xorg.conf. So nothing is forced, plain xorg autoconfig. Yet, no effect.
Nvidia 418.56 and Plasma with kwin here.
No change at all. It still takes almost 30 seconds to clock down.
If I turn Composition Pipeline on, clocks stay at max speed INDEFINITELY.
Hence I have to keep it off and experience terrible desktop tearing.
Hi All,
I observed that exporting variable __GL_ExperimentalPerfStrategy does not work for few users.
So in order to isolate issue, requesting you to share nvidia bug report; desktop environment being used and detailed repro steps.
A few? So far I haven’t seen a single person who’s reported success with this environment variable.
Here’s my config:
My Xorg config:
$ cat /etc/X11/xorg.conf.d/99-nvidia.conf.fast
Section "Device"
Identifier "Videocard0"
BusID "PCI:1:0:0"
Driver "nvidia"
VendorName "NVIDIA"
BoardName "NVIDIA Corporation GP106 [GeForce GTX 1060 6GB] (rev a1)"
Option "Coolbits" "28"
Option "UseNvKmsCompositionPipeline" "Off"
Option "TripleBuffer" "On"
EndSection
Distro: Fedora 29 with all updates installed
DE: XFCE without compositing
GPU: GTX 1060 6GB (no overclock, underclock or anything like that - runs 100% stock settings)
Drivers: OpenGL version string: 4.6.0 NVIDIA 418.56
Steps to reproduce:
Run watch -n1 nvidia-smi in a terminal.
Run any OpenGL demo or any OpenGL demo in a browser and then stop/exit them.
Count.
The net result: 36 seconds from P0 to P8 which is unacceptable. 3 seconds must be enough. In a perfect world 1 second should be enough.
Again, I’d like this option available as a kernel module option since it’s a much more reliable way or at the very list controlled by NVAPI.
This is my test, variable is set in /etc/environment and sourced correctly; i run glxgears for 3 seconds and next i check the clocks.
The first time it goes down in 3 seconds, but in the next run, it takes the canonical 30+ seconds, see:
############# 3 seconds, yay! :D
koko@Gozer# grep GL_ExperimentalPerfStrategy /etc/environment ; echo $__GL_ExperimentalPerfStrategy ; while true ; do nvidia-smi dmon -c 1 ; timeout 3 glxgears ; for i in $(seq 1 50) ; do nvidia-smi dmon -c 1 ; sleep 1 ; done ; done
1
# gpu pwr gtemp mtemp sm mem enc dec mclk pclk
# Idx W C C % % % % MHz MHz
0 1 33 - 5 10 0 0 405 135
0 12 38 - 88 2 0 0 2700 1215
0 4 36 - 1 2 0 0 2700 1215
0 4 36 - 0 1 0 0 2700 1215
0 4 34 - 2 10 0 0 405 340
0 1 33 - 0 9 0 0 405 340
0 1 33 - 2 10 0 0 405 340
0 0 33 - 0 9 0 0 405 135
0 1 33 - 4 10 0 0 405 135
0 0 33 - 4 10 0 0 405 135
^C
################# 35 seconds, DAMN :(
1
0 0 33 - 3 11 0 0 405 135
0 9 38 - 91 2 0 0 2700 1215
0 3 37 - 0 2 0 0 2700 1215
0 3 36 - 0 2 0 0 2700 1215
0 3 37 - 0 1 0 0 2700 1215
0 3 37 - 1 1 0 0 2700 1215
0 4 37 - 1 2 0 0 2700 1215
0 3 38 - 1 2 0 0 2700 1215
0 3 38 - 0 1 0 0 2700 1215
0 1 35 - 4 10 0 0 405 275
0 1 35 - 0 9 0 0 405 275
0 1 35 - 6 10 0 0 405 135
0 1 34 - 0 9 0 0 405 135
During the test i used KDE plasma without compositing, nothing else was running.
now i just repeated the test (while writing), and here are the results, 30 seconds:
1
0 1 33 - 0 9 0 0 405 254
0 10 39 - 89 2 0 0 2700 1215
0 4 37 - 0 2 0 0 2700 1215
0 4 37 - 0 1 0 0 2700 1215
0 4 38 - 0 2 0 0 2700 1215
0 4 38 - 0 1 0 0 2700 1215
0 4 36 - 0 9 0 0 405 275
0 1 35 - 0 10 0 0 405 275
^C
nvidia-bug-report.log.gz (1.28 MB)
