Image processing before preprocessing in nvinfer
• Hardware Platform (Jetson / GPU) Jetson TX2
• DeepStream Version 5.1
• TensorRT Version 7.1.3
• Issue Type( questions, new requirements, bugs) question
Hi
What kind of image processing does nvinfer do before preprocessing? I know, that nvinfer can do resize, padding and other operations, which could be configure in config.
My question is: are there any image conversations before preprocessing? Can I dump my original image from nvinfer before it goes to preprocessing?
Please refer to our nvinfer flowchart FAQ first.
There are also references on how to obtain image data.
Thanks, I’ll check it out
Also, I wonder, how can I get frame from NVMM buffer when using nvvideoconvert ! video/x-raw,(memory:NVMM). I attached pad probe to nvvideoconvert/src, but don’t know, how to copy frame from device memory to host, using received buffer?
This step will help me to determine, what kind of data is received by nvinfer
You can try to dump the image data in our open source. Please refer to this FAQ.
