I’m working on a detection (pgie) - alignment (image processing) - recognition(sgie) pipeline. I want to use the output from detection (key points) and full frame to do alignment before feeding the aligned image to sgie. The point here is keeping the whole pipeline on gpu. Can you give me some suggestions?
• DeepStream Version
• TensorRT Version
For your question, I think you can do that on the sgie
Idon’t know how I can do image processing (with opencv) on sgie. My intention is using customized gst-dsexample. For now I’m having trouble with getting the frame from buffer.
In addition, I don’t understand why nvidia uses cpu version of opencv for processing there. Isn’t it a bottleneck in the pipeline?
It’s just for demo how to use opencv, you can use Buffer Management API module — Deepstream Deepstream Version: 5.1 documentation for better perf
