Hi I’m looking to do image registration/translation on the Xavier using the Phase Cross Correlation algorithm (please refer to the algorithm of the same name from skimage in Python). Do I do this using the Deepstream 5.0 SDK, or the Optical Flow SDK? Can you please direct me to sample files? What fps is achievable? Are there similar algorithms that I could use for which Deepstream has already been adapted to give optimum performance? Thanks
Related topics
| optical flow | 2 | 827 | October 12, 2021 | |
| is there option to run my model on top of deepstream SDK | 3 | 716 | October 18, 2021 | |
| DeepStream SDK for Redaction on Xavier | 1 | 514 | April 11, 2019 | |
| image segmentation | 2 | 2209 | October 12, 2021 | |
| License plate recognition | 5 | 2178 | October 12, 2021 | |
| Running image fusion on Jetson Orin Nano with deepstream python apps | 15 | 1012 | August 9, 2024 | |
| Template for OpenCV | 2 | 321 | April 27, 2020 | |
| Deep Stream SDK | 4 | 642 | October 12, 2021 | |
| Cannot find the objectDetector_FastRCNN example | 46 | 867 | October 14, 2024 | |
| Using Calibration to Translate Video Data to the Real World | 6 | 661 | May 10, 2021 |
