This is the basic test on Jetson nano, should work well, any idea? Thanks in advance!
==Running log with segmentation fault
~/Downloads/jetson-inference/build/aarch64/bin$ ./imagenet-console orange_0.jpg orange-out.jpg
imagenet-console
args (3): 0 [./imagenet-console] 1 [orange_0.jpg] 2 [orange-out.jpg]
imageNet – loading classification network model from:
– prototxt networks/googlenet.prototxt
– model networks/bvlc_googlenet.caffemodel
– class_labels networks/ilsvrc12_synset_words.txt
– input_blob ‘data’
– output_blob ‘prob’
– batch_size 2
[TRT] TensorRT version 5.0.6
[TRT] detected model format - caffe (extension ‘.caffemodel’)
[TRT] desired precision specified for GPU: FASTEST
[TRT] requested fasted precision for device GPU without providing valid calibrator, disabling INT8
[TRT] native precisions detected for GPU: FP32, FP16
[TRT] selecting fastest native precision for GPU: FP16
[TRT] attempting to open engine cache file networks/bvlc_googlenet.caffemodel.2.1.GPU.FP16.engine
[TRT] cache file not found, profiling network model on device GPU
[TRT] device GPU, loading networks/googlenet.prototxt networks/bvlc_googlenet.caffemodel
[TRT] failed to retrieve tensor for Output “prob”
[TRT] device GPU, configuring CUDA engine
[TRT] device GPU, building FP16: ON
[TRT] device GPU, building INT8: OFF
[TRT] device GPU, building CUDA engine (this may take a few minutes the first time a network is loaded)
==using valgrind to check, sounds buildGraph function encounter NULL pointer, any idea
==10465== Invalid read of size 8
==10465== at 0x4FCFC20: nvinfer1::builder::buildGraph(nvinfer1::CudaEngineBuildConfig const&, nvinfer1::builder::Graph&, nvinfer1::Network const&) (in /usr/lib/aarch64-linux-gnu/libnvinfer.so.5.0.6)
==10465== by 0x4FD0183: nvinfer1::builder::buildEngine(nvinfer1::CudaEngineBuildConfig&, nvinfer1::rt::HardwareContext const&, nvinfer1::Network const&) (in /usr/lib/aarch64-linux-gnu/libnvinfer.so.5.0.6)
==10465== by 0x503C9F3: nvinfer1::builder::Builder::buildCudaEngine(nvinfer1::INetworkDefinition&) (in /usr/lib/aarch64-linux-gnu/libnvinfer.so.5.0.6)
==10465== by 0x491B1E7: tensorNet::ProfileModel(std::__cxx11::basic_string<char, std::char_traits, std::allocator > const&, std::__cxx11::basic_string<char, std::char_traits, std::allocator > const&, std::vector<std::__cxx11::basic_string<char, std::char_traits, std::allocator >, std::allocator<std::__cxx11::basic_string<char, std::char_traits, std::allocator > > > const&, unsigned int, precisionType, deviceType, bool, nvinfer1::IInt8Calibrator*, std::ostream&) (in /home/bz/Downloads/jetson-inference/build/aarch64/lib/libjetson-inference.so)
==10465== by 0x491B973: tensorNet::LoadNetwork(char const*, char const*, char const*, char const*, std::vector<std::__cxx11::basic_string<char, std::char_traits, std::allocator >, std::allocator<std::__cxx11::basic_string<char, std::char_traits, std::allocator > > > const&, unsigned int, precisionType, deviceType, bool, nvinfer1::IInt8Calibrator*, CUstream_st*) (in /home/bz/Downloads/jetson-inference/build/aarch64/lib/libjetson-inference.so)
==10465== by 0x491B44B: tensorNet::LoadNetwork(char const*, char const*, char const*, char const*, char const*, unsigned int, precisionType, deviceType, bool, nvinfer1::IInt8Calibrator*, CUstream_st*) (in /home/bz/Downloads/jetson-inference/build/aarch64/lib/libjetson-inference.so)
==10465== by 0x491679B: imageNet::init(char const*, char const*, char const*, char const*, char const*, char const*, unsigned int, precisionType, deviceType, bool) (in /home/bz/Downloads/jetson-inference/build/aarch64/lib/libjetson-inference.so)
==10465== by 0x49165EB: imageNet::init(imageNet::NetworkType, unsigned int, precisionType, deviceType, bool) (in /home/bz/Downloads/jetson-inference/build/aarch64/lib/libjetson-inference.so)
==10465== by 0x49163A7: imageNet::Create(imageNet::NetworkType, unsigned int, precisionType, deviceType, bool) (in /home/bz/Downloads/jetson-inference/build/aarch64/lib/libjetson-inference.so)
==10465== by 0x4916BEF: imageNet::Create(int, char**) (in /home/bz/Downloads/jetson-inference/build/aarch64/lib/libjetson-inference.so)
==10465== by 0x11074B: main (in /home/bz/Downloads/jetson-inference/build/aarch64/bin/imagenet-console)
==10465== Address 0x0 is not stack’d, malloc’d or (recently) free’d
==10465==
==10465==
==10465== Process terminating with default action of signal 11 (SIGSEGV)
==10465== Access not within mapped region at address 0x0
