Yes the command worked
Just for your interest
cat /etc/nvidia-container-runtime/host-files-for-container.d/l4t.csv
dev, /dev/fb0
dev, /dev/fb1
dev, /dev/nvhost-as-gpu
dev, /dev/nvhost-ctrl
dev, /dev/nvhost-ctrl-gpu
dev, /dev/nvhost-dbg-gpu
dev, /dev/nvhost-gpu
dev, /dev/nvhost-nvdec
dev, /dev/nvhost-nvdec1
dev, /dev/nvhost-prof-gpu
dev, /dev/nvhost-vic
dev, /dev/nvhost-ctrl-nvdla0
dev, /dev/nvhost-ctrl-nvdla1
dev, /dev/nvhost-nvdla0
dev, /dev/nvhost-nvdla1
dev, /dev/nvidiactl
dev, /dev/nvmap
dev, /dev/tegra_dc_0
dev, /dev/tegra_dc_1
dev, /dev/tegra_dc_ctrl
dev, /dev/nvhost-msenc
dev, /dev/nvhost-nvenc1
dev, /dev/nvhost-nvjpg
dev, /dev/nvhost-nvjpg1
dev, /dev/nvhost-ctrl-pva0
dev, /dev/nvhost-ctrl-pva1
dev, /dev/nvhost-ofa
dev, /dev/nvhost-pva0
dev, /dev/nvhost-pva1
dev, /dev/nvgpu/igpu0/as
dev, /dev/nvgpu/igpu0/channel
dev, /dev/nvgpu/igpu0/ctrl
dev, /dev/nvgpu/igpu0/ctxsw
dev, /dev/nvgpu/igpu0/dbg
dev, /dev/nvgpu/igpu0/power
dev, /dev/nvgpu/igpu0/prof
dev, /dev/nvgpu/igpu0/prof-ctx
dev, /dev/nvgpu/igpu0/prof-dev
dev, /dev/nvgpu/igpu0/tsg
dev, /dev/host1x
dir, /lib/firmware/tegra19x
dir, /lib/firmware/tegra18x
dir, /lib/firmware/tegra21x
lib, /usr/lib/aarch64-linux-gnu/libv4l2.so.0
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/desktop-shell.so
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/drm-backend.so
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/EGLWLInputEventExample
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/EGLWLMockNavigation
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/fullscreen-shell.so
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/gl-renderer.so
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/hmi-controller.so
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/ivi-controller.so
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/ivi-shell.so
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/LayerManagerControl
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/libilmClient.so.2.2.0
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/libilmCommon.so.2.2.0
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/libilmControl.so.2.2.0
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/libilmInput.so.2.2.0
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/libweston-6.so.0
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/libweston-desktop-6.so.0
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/simple-weston-client
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/spring-tool
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/wayland-backend.so
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-calibrator
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-clickdot
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-cliptest
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-content-protection
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-debug
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-desktop-shell
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-dnd
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-eventdemo
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-flower
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-fullscreen
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-image
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-info
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-ivi-shell-user-interface
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-keyboard
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-launch
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-multi-resource
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-output-mode
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-resizor
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-scaler
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-screenshooter
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-simple-dmabuf-egldevice
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-simple-egl
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-simple-shm
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-simple-touch
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-smoke
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-stacking
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-subsurfaces
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-terminal
lib, /usr/lib/aarch64-linux-gnu/tegra/weston/weston-transformed
lib, /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so
lib, /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvcompositor.so
lib, /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvdrmvideosink.so
lib, /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnveglglessink.so
lib, /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnveglstreamsrc.so
lib, /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvegltransform.so
lib, /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvivafilter.so
lib, /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvjpeg.so
lib, /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvtee.so
lib, /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvv4l2camerasrc.so
lib, /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvidconv.so
lib, /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so
lib, /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideosink.so
lib, /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideosinks.so
lib, /usr/lib/aarch64-linux-gnu/libgstnvegl-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstnvexifmeta.so
lib, /usr/lib/aarch64-linux-gnu/libgstnvivameta.so
lib, /usr/lib/aarch64-linux-gnu/libnvsample_cudaprocess.so
lib, /etc/vulkansc/icd.d/nvidia_icd_vksc.json
lib, /usr/lib/aarch64-linux-gnu/tegra-egl/ld.so.conf
lib, /usr/lib/aarch64-linux-gnu/tegra-egl/libEGL_nvidia.so.0
lib, /usr/lib/aarch64-linux-gnu/tegra-egl/libGLESv1_CM_nvidia.so.1
lib, /usr/lib/aarch64-linux-gnu/tegra-egl/libGLESv2_nvidia.so.2
lib, /usr/lib/aarch64-linux-gnu/tegra-egl/nvidia.json
lib, /usr/lib/aarch64-linux-gnu/tegra/ld.so.conf
lib, /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1
lib, /usr/lib/aarch64-linux-gnu/tegra/libdrm.so.2
lib, /usr/lib/aarch64-linux-gnu/tegra/libGLX_nvidia.so.0
lib, /usr/lib/aarch64-linux-gnu/tegra/libgstnvcustomhelper.so.1.0.0
lib, /usr/lib/aarch64-linux-gnu/tegra/libgstnvdsseimeta.so.1.0.0
lib, /usr/lib/aarch64-linux-gnu/tegra/libjetsonpower.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvargus.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvargus_socketclient.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvargus_socketserver.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvbuf_fdmap.so.1.0.0
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurface.so.1.0.0
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurftransform.so.1.0.0
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvcameratools.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvcamerautils.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvcam_imageencoder.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvcamlog.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvcamv4l2.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvcapture.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvcolorutil.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvcucompat.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvcuvidv4l2.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvdc.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvddk_2d_v2.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvddk_vic.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvdecode2eglimage.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvdla_compiler.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvdla_runtime.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvdsbufferpool.so.1.0.0
lib, /usr/lib/aarch64-linux-gnu/tegra/libnveglstreamproducer.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnveventlib.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvexif.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvfnet.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvfnetstoredefog.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvfnetstorehdfx.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvfusacapinterface.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvfusacap.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvgov_boot.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvgov_camera.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvgov_force.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvgov_generic.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvgov_gpucompute.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvgov_graphics.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvgov_il.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvgov_spincircle.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvgov_tbc.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvgov_ui.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvidia-allocator.so.1
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvidia-eglcore.so.35.4.1
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvidia-egl-gbm.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvidia-egl-wayland.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvidia-glcore.so.35.4.1
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvidia-glsi.so.35.4.1
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvidia-glvkspirv.so.35.4.1
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvidia-kms.so.35.4.1
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvidia-nvvm.so.35.4.1
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvidia-ptxjitcompiler.so.35.4.1
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvidia-rmapi-tegra.so.35.4.1
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvidia-rtcore.so.35.4.1
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvidia-tls.so.35.4.1
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvidia-vksc-core.so.35.4.1
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvidia-vulkan-producer.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvid_mapper.so.1.0.0
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvimp.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvisppg.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvisp.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvisp_utils.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvjpeg.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvll.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvmedia_2d.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvmedia2d.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvmedia_dla.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvmedia_eglstream.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvmedia_ide_parser.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvmedia_ide_sci.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvmedia_iep_sci.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvmedia_ijpd_sci.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvmedia_ijpe_sci.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvmedia_iofa_sci.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvmedia_isp_ext.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvmedialdc.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvmedia_sci_overlay.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvmedia.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvmedia_tensor.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvmm_contentpipe.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvmmlite_image.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvmmlite.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvmmlite_utils.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvmmlite_video.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvmm_parser.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvmm.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvmm_utils.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvodm_imager.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvofsdk.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvoggopus.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvomxilclient.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvomx.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvosd.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvos.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvparser.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvphsd.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvphs.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvpva_algorithms.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvpvaintf.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvpva.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvpvaumd.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvrm_chip.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvrm_gpu.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvrm_host1x.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvrm_mem.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvrm_stream.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvrm_surface.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvrm_sync.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvscf.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvscibuf.so.1
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvscicommon.so.1
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvscievent.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvsciipc.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvscistream.so.1
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvscisync.so.1
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvsocsys.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvtracebuf.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvtvmr_2d.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvtvmr.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvv4l2.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvv4lconvert.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvvic.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvvideoencode_ppe.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libnvvideo.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libsensors.hal-client.nvs.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libsensors_hal.nvs.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libsensors.l4t.no_fusion.nvs.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libtegrav4l2.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libtegrawfd.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libv4l2_nvargus.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libv4l2_nvcuvidvideocodec.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libv4l2_nvvideocodec.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libVkLayer_json_gen.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libVkSCLayer_khronos_validation.so
lib, /usr/lib/aarch64-linux-gnu/tegra/libvulkansc.so.1.0.10
lib, /usr/lib/aarch64-linux-gnu/tegra/libvulkan.so.1.3.204
lib, /usr/lib/aarch64-linux-gnu/tegra/nvidia_icd.json
sym, /etc/vulkan/icd.d/nvidia_icd.json
sym, /usr/lib/aarch64-linux-gnu/gbm/nvidia-drm_gbm.so
sym, /usr/lib/aarch64-linux-gnu/gbm/tegra_gbm.so
sym, /usr/lib/aarch64-linux-gnu/gbm/tegra-udrm_gbm.so
sym, /usr/lib/aarch64-linux-gnu/libcuda.so
sym, /usr/lib/aarch64-linux-gnu/libnvcucompat.so
sym, /usr/lib/aarch64-linux-gnu/libv4l2.so.0.0.999999
sym, /usr/lib/aarch64-linux-gnu/libv4lconvert.so.0.0.999999
sym, /usr/lib/aarch64-linux-gnu/libv4l/plugins/nv/libv4l2_nvargus.so
sym, /usr/lib/aarch64-linux-gnu/libv4l/plugins/nv/libv4l2_nvcuvidvideocodec.so
sym, /usr/lib/aarch64-linux-gnu/libv4l/plugins/nv/libv4l2_nvvideocodec.so
sym, /usr/lib/aarch64-linux-gnu/libvulkan.so.1.3.204
sym, /usr/lib/aarch64-linux-gnu/tegra/libcuda.so
sym, /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1
sym, /usr/lib/aarch64-linux-gnu/tegra/libgstnvcustomhelper.so
sym, /usr/lib/aarch64-linux-gnu/tegra/libgstnvdsseimeta.so
sym, /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurface.so
sym, /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurftransform.so
sym, /usr/lib/aarch64-linux-gnu/tegra/libnvdsbufferpool.so
sym, /usr/lib/aarch64-linux-gnu/tegra/libnvidia-allocator.so
sym, /usr/lib/aarch64-linux-gnu/tegra/libnvidia-egl-gbm.so.1
sym, /usr/lib/aarch64-linux-gnu/tegra/libnvidia-egl-wayland.so.1
sym, /usr/lib/aarch64-linux-gnu/tegra/libnvidia-kms.so
sym, /usr/lib/aarch64-linux-gnu/tegra/libnvidia-nvvm.so.4
sym, /usr/lib/aarch64-linux-gnu/tegra/libnvidia-ptxjitcompiler.so.1
sym, /usr/lib/aarch64-linux-gnu/tegra/libnvidia-vksc-core.so
sym, /usr/lib/aarch64-linux-gnu/tegra/libnvid_mapper.so
sym, /usr/lib/aarch64-linux-gnu/tegra/libnvscibuf.so
sym, /usr/lib/aarch64-linux-gnu/tegra/libnvscicommon.so
sym, /usr/lib/aarch64-linux-gnu/tegra/libnvscistream.so
sym, /usr/lib/aarch64-linux-gnu/tegra/libnvscisync.so
sym, /usr/lib/aarch64-linux-gnu/tegra/libv4l2.so.0
sym, /usr/lib/aarch64-linux-gnu/tegra/libv4lconvert.so.0
sym, /usr/lib/aarch64-linux-gnu/tegra/libvulkansc.so
sym, /usr/lib/aarch64-linux-gnu/tegra/libvulkansc.so.1
sym, /usr/lib/aarch64-linux-gnu/tegra/libvulkan.so.1
sym, /usr/share/glvnd/egl_vendor.d/10_nvidia.json
lib, //lib/firmware/tegra19x/nvhost_nvdec040_ns.fw
lib, /lib/firmware/tegra19x/nvhost_nvdec040_ns.fw
lib, /lib/firmware/tegra23x/nvhost_nvdec050_desc_prod.bin
