Hello, I am trying to use 2 IMX 219 cameras to work within the jetson-inference container provided by the docker provided by the jetson-inference github page. Ive tried to rebbot, make sure cameras were properly connected, and checked the cameras work fine outside the container which they do. also, when i purchased the cameras they had me download a new .isp file to correct for reddish color, im not sure if that would have messed with anything
Here are the logs:
first i start the container:
docker/run.sh
ARCH: aarch64
reading L4T version from /etc/nv_tegra_release
L4T BSP Version: L4T R35.3.1
[sudo] password for eppl-sp:
localuser:root being added to access control list
CONTAINER_IMAGE: dustynv/jetson-inference:r35.3.1
DATA_VOLUME: --volume /home/eppl-sp/jetson-inference/data:/jetson-inference/data --volume /home/eppl-sp/jetson-inference/python/training/classification/data:/jetson-inference/python/training/classification/data --volume /home/eppl-sp/jetson-inference/python/training/classification/models:/jetson-inference/python/training/classification/models --volume /home/eppl-sp/jetson-inference/python/training/detection/ssd/data:/jetson-inference/python/training/detection/ssd/data --volume /home/eppl-sp/jetson-inference/python/training/detection/ssd/models:/jetson-inference/python/training/detection/ssd/models --volume /home/eppl-sp/jetson-inference/python/www/recognizer/data:/jetson-inference/python/www/recognizer/data
V4L2_DEVICES: --device /dev/video0 --device /dev/video1
DISPLAY_DEVICE: -e DISPLAY=:1 -v /tmp/.X11-unix/:/tmp/.X11-unix
video-viewer csi://0
(gst-plugin-scanner:22): GStreamer-WARNING **: 23:14:06.500: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvegltransform.so': /lib/aarch64-linux-gnu/libGLdispatch.so.0: cannot allocate memory in static TLS block
(gst-plugin-scanner:22): GStreamer-WARNING **: 23:14:06.507: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnveglstreamsrc.so': /lib/aarch64-linux-gnu/libGLdispatch.so.0: cannot allocate memory in static TLS block
(gst-plugin-scanner:22): GStreamer-WARNING **: 23:14:06.513: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvcompositor.so': /lib/aarch64-linux-gnu/libGLdispatch.so.0: cannot allocate memory in static TLS block
(gst-plugin-scanner:22): GStreamer-WARNING **: 23:14:06.520: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvjpeg.so': /lib/aarch64-linux-gnu/libGLdispatch.so.0: cannot allocate memory in static TLS block
(gst-plugin-scanner:22): GStreamer-WARNING **: 23:14:06.526: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvidconv.so': /lib/aarch64-linux-gnu/libGLdispatch.so.0: cannot allocate memory in static TLS block
(gst-plugin-scanner:22): GStreamer-WARNING **: 23:14:06.530: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideosink.so': /lib/aarch64-linux-gnu/libGLdispatch.so.0: cannot allocate memory in static TLS block
(gst-plugin-scanner:22): GStreamer-WARNING **: 23:14:06.535: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideosinks.so': /lib/aarch64-linux-gnu/libGLdispatch.so.0: cannot allocate memory in static TLS block
(gst-plugin-scanner:22): GStreamer-WARNING **: 23:14:06.542: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvivafilter.so': /lib/aarch64-linux-gnu/libGLdispatch.so.0: cannot allocate memory in static TLS block
(gst-plugin-scanner:22): GStreamer-WARNING **: 23:14:06.548: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so': /lib/aarch64-linux-gnu/libGLdispatch.so.0: cannot allocate memory in static TLS block
(gst-plugin-scanner:22): GStreamer-WARNING **: 23:14:06.551: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvv4l2camerasrc.so': /lib/aarch64-linux-gnu/libGLdispatch.so.0: cannot allocate memory in static TLS block
(gst-plugin-scanner:22): GStreamer-WARNING **: 23:14:06.555: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnveglglessink.so': /lib/aarch64-linux-gnu/libGLdispatch.so.0: cannot allocate memory in static TLS block
(gst-plugin-scanner:22): GStreamer-WARNING **: 23:14:06.571: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so': /lib/aarch64-linux-gnu/libGLdispatch.so.0: cannot allocate memory in static TLS block
[gstreamer] initialized gstreamer, version 1.16.3.0
[gstreamer] gstCamera -- attempting to create device csi://0
[gstreamer] gstCamera pipeline string:
[gstreamer] nvarguscamerasrc sensor-id=0 ! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=30/1, format=(string)NV12 ! nvvidconv flip-method=2 ! video/x-raw ! appsink name=mysink
[gstreamer] gstCamera failed to create pipeline
[gstreamer] (no element "nvarguscamerasrc")
[gstreamer] gstCamera -- failed to create device csi://0
video-viewer: failed to create input stream
video-viewer csi://1
[gstreamer] gstCamera -- attempting to create device csi://1
[gstreamer] nvarguscamerasrc sensor-id=1 ! video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=30/1, format=(string)NV12 ! nvvidconv flip-method=2 ! video/x-raw ! appsink name=mysink
[gstreamer] gstCamera -- failed to create device csi://1
then, i tried export LD_PRELOAD=/lib/aarch64-linux-gnu/libGLdispatch.so.0 inside the container, and used gst inspect:
gst-inspect-1.0 --version
gst-inspect-1.0 version 1.16.3
GStreamer 1.16.3
https://launchpad.net/distros/ubuntu/+source/gstreamer1.0
gst-inspect-1.0 | grep nv
root@epplsp-desktop:/jetson-inference# gst-inspect-1.0 | grep nv
nvdrmvideosink: nvdrmvideosink: Nvidia Drm Video Sink
nvtee: nvtee: NvTee
audiofx: audioinvert: Audio inversion
libav: avdec_twinvq: libav VQF TwinVQ decoder
libav: avdec_dsicinvideo: libav Delphine Software International CIN video decoder
libav: avdec_idcinvideo: libav id Quake II CIN video decoder
libav: avdec_wnv1: libav Winnov WNV1 decoder
rtponvif: rtponviftimestamp: ONVIF NTP timestamps RTP extension
rtponvif: rtponvifparse: ONVIF NTP timestamps RTP extension
videoconvert: videoconvert: Colorspace converter
autoconvert: autoconvert: Select convertor based on caps
autoconvert: autovideoconvert: Select color space convertor based on caps
closedcaption: ccconverter: Closed Caption Converter
debugutilsbad: errorignore: Convert some GstFlowReturn types into others
ivtc: ivtc: Inverse Telecine
audioconvert: audioconvert: Audio converter
bayer: rgb2bayer: RGB to Bayer converter
ls -ll /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnv*
-rw-r--r-- 1 root root 68544 Mar 19 15:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so
-rw-r--r-- 1 root root 35608 Mar 19 15:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvcompositor.so
-rw-r--r-- 1 root root 39672 Mar 19 15:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvdrmvideosink.so
-rw-r--r-- 1 root root 742592 Mar 19 15:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnveglglessink.so
-rw-r--r-- 1 root root 31320 Mar 19 15:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnveglstreamsrc.so
-rw-r--r-- 1 root root 27152 Mar 19 15:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvegltransform.so
-rw-r--r-- 1 root root 48168 Mar 19 15:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvivafilter.so
-rw-r--r-- 1 root root 52504 Mar 19 15:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvjpeg.so
-rw-r--r-- 1 root root 18936 Mar 19 15:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvtee.so
-rw-r--r-- 1 root root 35416 Mar 19 15:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvv4l2camerasrc.so
-rw-r--r-- 1 root root 700712 Mar 19 15:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvidconv.so
-rw-r--r-- 1 root root 275328 Mar 19 15:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so
-rw-r--r-- 1 root root 35488 Mar 19 15:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideosink.so
-rw-r--r-- 1 root root 721312 Mar 19 15:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideosinks.so
this is the same commands but outside the container:
$ gst-inspect-1.0 --version
GStreamer 1.16.3
$ gst-inspect-1.0 | grep nv
nvarguscamerasrc: nvarguscamerasrc: NvArgusCameraSrc
nveglglessink: nveglglessink: EGL/GLES vout Sink
opengl: glviewconvert: OpenGL Multiview/3D conversion filter
opengl: gleffects_laplacian: Laplacian Convolution Demo Effect
opengl: gleffects_blur: Blur with 9x9 separable convolution Effect
opengl: glcolorconvert: OpenGL color converter
nvv4l2camerasrc: nvv4l2camerasrc: NvV4l2CameraSrc
nvvideo4linux2: nvv4l2av1enc: V4L2 AV1 Encoder
nvvideo4linux2: nvv4l2vp9enc: V4L2 VP9 Encoder
nvvideo4linux2: nvv4l2vp8enc: V4L2 VP8 Encoder
nvvideo4linux2: nvv4l2h265enc: V4L2 H.265 Encoder
nvvideo4linux2: nvv4l2h264enc: V4L2 H.264 Encoder
nvvideo4linux2: nvv4l2decoder: NVIDIA v4l2 video decoder
nvivafilter: nvivafilter: NvIVAFilter Plugin
nvvideosinks: nv3dsink: Nvidia 3D sink
nvvideosink: nvvideosink: nVidia Video Sink
nvvidconv: nvvidconv: NvVidConv Plugin
nvjpeg: nvjpegdec: JPEG image decoder
nvjpeg: nvjpegenc: JPEG image encoder
nvcompositor: nvcompositor: NvCompositor
nvtee: nvtee: NvTee
nveglstreamsrc: nveglstreamsrc: nVidia EGL Stream
nvegltransform: nvegltransform: NvEGLTransform
nvdsgst_dewarper: nvdewarper: nvdewarper
nvdsgst_tracker: nvtracker: NvTracker plugin
nvdsgst_dsanalytics: nvdsanalytics: DsAnalytics plugin
nvdsgst_msgbroker: nvmsgbroker: Message Broker
nvdsgst_postprocess: nvdspostprocess: NvDsPostProcess plugin for Transform/In-Place use-cases
nvdsgst_osd: nvdsosd: NvDsOsd plugin
nvdsgst_metamux: nvdsmetamux: meta muxer
nvdsgst_msgconv: nvmsgconv: Message Converter
nvdsgst_multistreamtiler: nvmultistreamtiler: Stream Tiler DS
nvdsgst_ofvisual: nvofvisual: nvofvisual
nvdsgst_dsexample: dsexample: DsExample plugin
nvdsgst_audiotemplate: nvdsaudiotemplate: DS AUDIO template Plugin for Transform IP use-cases
nvdsgst_of: nvof: nvof
nvdsgst_inferaudio: nvinferaudio: NvInfer Audio plugin
nvdsgst_logger: nvdslogger: Nvdslogger
nvdsgst_3dfilter: nvds3dfilter: DS 3D filter custom plugin
nvdsgst_segvisual: nvsegvisual: nvsegvisual
nvdsgst_speech: nvdsasr: DS ASR Plugin for speech use-cases
nvdsgst_preprocess: nvdspreprocess: gst-nvdspreprocess plugin
nvvideoconvert: nvvideoconvert: NvVidConv Plugin
nvdsgst_infer: nvinfer: NvInfer plugin
nvdsgst_multistream: nvstreamdemux: Stream demultiplexer
nvdsgst_multistream: nvstreammux: Stream multiplexer
nvdsgst_text_to_speech: nvds_text_to_speech: DS Text To Speech Plugin for Conversational AI use cases
nvdsgst_videotemplate: nvdsvideotemplate: NvDsVideoTemplate plugin for Transform/In-Place use-cases
$ ls -ll /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnv*
-rw-r--r-- 1 root root 68544 Mar 19 11:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvarguscamerasrc.so
-rw-r--r-- 1 root root 35608 Mar 19 11:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvcompositor.so
-rw-r--r-- 1 root root 39672 Mar 19 11:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvdrmvideosink.so
-rw-r--r-- 1 root root 742592 Mar 19 11:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnveglglessink.so
-rw-r--r-- 1 root root 31320 Mar 19 11:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnveglstreamsrc.so
-rw-r--r-- 1 root root 27152 Mar 19 11:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvegltransform.so
-rw-r--r-- 1 root root 48168 Mar 19 11:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvivafilter.so
-rw-r--r-- 1 root root 52504 Mar 19 11:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvjpeg.so
-rw-r--r-- 1 root root 18936 Mar 19 11:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvtee.so
-rw-r--r-- 1 root root 35416 Mar 19 11:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvv4l2camerasrc.so
-rw-r--r-- 1 root root 700712 Mar 19 11:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvidconv.so
-rw-r--r-- 1 root root 275328 Mar 19 11:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so
-rw-r--r-- 1 root root 35488 Mar 19 11:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideosink.so
-rw-r--r-- 1 root root 721312 Mar 19 11:14 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideosinks.so
