Originally published at: https://developer.nvidia.com/blog/implementing-high-precision-decimal-arithmetic-with-cuda-int128/
This post details CUDA’s new int128 support and how to implement decimal fixed-point arithmetic on top of it.
jwitsoe
1
Related topics
Topic | Replies | Views | Activity | |
Emulated double precision Double single routine header | 24 | 49142 | October 18, 2010 | |
Bitslice-DES optimization | 55 | 12595 | January 29, 2022 | |
Possible to use the CUDA math API integer intrinsics to find the nth unset bit in a 32 bit int | 37 | 8437 | March 1, 2015 | |
Accuracy of 1D linear interpolation by CUDA texture interpolation | 25 | 14617 | January 29, 2013 | |
CUDA Pro Tip: Use cuFFT Callbacks for Custom Data Processing | 18 | 1206 | August 15, 2023 | |
Mixed-Precision Programming with CUDA 8 | 1 | 387 | February 23, 2017 | |
A more accurate, performance-competitive implementation of expf() | 24 | 8134 | November 19, 2017 | |
Accuracy in GPU floating point calculations | 35 | 8227 | September 9, 2011 | |
GPU/CPU precision comparison and Kernel instructions question | 5 | 677 | April 4, 2017 | |
Optimized version of single-precision error function, erff() | 21 | 4445 | December 25, 2017 |
