Can’t inizialize cuda, when i’m trying to run
import pycuda.autoinit()
or
import pycuda.driver as cuda
cuda.init()
programm works inifinite.
The problem begin to occure after restarting machine, i didn’t install anything.
or
cuda.init()
I’m facing similar issues. I’m using an AGX Xavier, Jetpack 4.4.1.
cuda.init()
works but following doesn’t work
pycuda is being used for tensorRT model definition so if pycuda.autoinit
is removed the last line of the following code block doesn’t work either.
logger = trt.Logger(trt.Logger.WARNING)
runtime = trt.Runtime(logger)
with open(f"{model_name}", "rb") as f:
model_trt = f.read()
self.model_trt = runtime.deserialize_cuda_engine(model_trt)
ctx = self.model_trt.create_execution_context()
