Continuing the discussion from Import pycuda.autoinit() works infinitely:
I’m using an AGX Xavier, Jetpack 4.4.1. This issue is blocking any further work for us.
import pycuda.driver as cuda
cuda.init()
works but following doesn’t work
import pycuda.autoinit
pycuda is being used for tensorRT model definition so if pycuda.autoinit
is removed the last line of the following code block doesn’t work either.
EDIT: the code hangs at trt.Runtime
logger = trt.Logger(trt.Logger.WARNING)
runtime = trt.Runtime(logger)
with open(f"{model_name}", "rb") as f:
model_trt = f.read()
self.model_trt = runtime.deserialize_cuda_engine(model_trt)
ctx = self.model_trt.create_execution_context()
