Hey guys. I’m trying to get TF working but it is giving me the error:
ImportError: libcudnn.so.6: cannot open shared object file: No such file or directory
I searched around and found that the Envvar LD_LIBRARY_PATH needs to be set and also that I need Cudnn 6 installed. I downloaded it from nvidia and installed to /usr/local/cuda/lib64 and linked the EnvVar to the directory. Now I can run $LD_LIBRARY_PATH/libcudnn.so.6 and it finds the file. However TF still throws the error that it cannot find the file! What can I check next?
I used the wheel file provided by JetsonHacks on github to install TF.
I’m on a Jetson tx1.
