I am trying Running TAO Toolkit on Google Colab.
Here is the link:
When I run the command below, it get this output
Using TensorFlow backend.
2024-08-22 06:31:05,003 [TAO Toolkit] [WARNING] tensorflow 40: Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
2024-08-22 06:31:06,159 [TAO Toolkit] [WARNING] root 329: Limited tf.compat.v2.summary API due to missing TensorBoard installation.
2024-08-22 06:31:06,795 [TAO Toolkit] [WARNING] root 329: Limited tf.compat.v2.summary API due to missing TensorBoard installation.
RuntimeError: module compiled against API version 0x10 but this version of numpy is 0xf
File “/usr/local/bin/yolo_v4_tiny”, line 8, in
sys.exit(main())
File “/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/yolo_v4/entrypoint/yolo_v4.py”, line 12, in main
launch_job(nvidia_tao_tf1.cv.yolo_v4.scripts, “yolo_v4”, sys.argv[1:])
File “/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/common/entrypoint/entrypoint.py”, line 276, in launch_job
modules = get_modules(package)
File “/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/common/entrypoint/entrypoint.py”, line 47, in get_modules
module = importlib.import_module(module_name)
File “/usr/lib/python3.8/importlib/init.py”, line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1014, in _gcd_import
File “”, line 991, in _find_and_load
File “”, line 975, in _find_and_load_unlocked
File “”, line 671, in _load_unlocked
File “”, line 843, in exec_module
File “”, line 219, in _call_with_frames_removed
File “/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/yolo_v4/scripts/train.py”, line 31, in
from nvidia_tao_tf1.cv.yolo_v4.models.utils import build_training_pipeline
File “/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/yolo_v4/models/utils.py”, line 13, in
from nvidia_tao_tf1.cv.yolo_v4.models.yolov4_model import YOLOv4Model
File “/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/yolo_v4/models/yolov4_model.py”, line 27, in
from nvidia_tao_tf1.cv.common.evaluator.ap_evaluator import APEvaluator
File “/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/common/evaluator/ap_evaluator.py”, line 25, in
from matplotlib import pyplot as plt
File “/usr/local/lib/python3.8/dist-packages/matplotlib/pyplot.py”, line 32, in
import matplotlib.colorbar
File “/usr/local/lib/python3.8/dist-packages/matplotlib/colorbar.py”, line 28, in
import matplotlib.artist as martist
File “/usr/local/lib/python3.8/dist-packages/matplotlib/artist.py”, line 11, in
from .path import Path
File “/usr/local/lib/python3.8/dist-packages/matplotlib/path.py”, line 17, in
from . import _path, rcParams
ImportError: numpy.core.multiarray failed to import
