In case of instance segmentation, is the principle of supporting the tracker internally using bbox information?
• Hardware Platform (Jetson / GPU) dGPU
• DeepStream Version 6.2
• TensorRT Version
hello
  1. First of all, deepstream supports all nvtrackers for instance segmentation, right?
  2. Then, it is possible because where is the bbox information including binary mask stored for an object internally?
DeepStream support instance segmentation.
nvtracker tracks the object based on the object, not instance segmentation mask.
Thank you
you mean that object is RectParam? tracks only based on t,l,w,h?
We have different tracker which based on rect/visual/Re-ID. Here is the nvtracker doc: Gst-nvtracker — DeepStream 6.2 Release documentation
