I am a new to GPU setting. I will set up nvidia-driver on Ubuntu18. But many try has failed for unknown reason.
env
- OS : Ubuntu 18.04.5 LTS
- GPU : RTX3090
- CPU : AMD® Ryzen 5 3500 6-core processor × 6
I think nvidia-driver-455 and cuda11.1.1 are right version from many website. I reinstalled Ubuntu, and tried NVIDIA official install flow on CUDA Toolkit 11.1 Update 1 Downloads | NVIDIA Developer
After rebooting, the command “nvidia-driver” results on
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
I saw /var/lib/dkms/nvidia/455.32.00/build/make.log written below
CONFTEST: drm_atomic_state_ref_counting
CONFTEST: drm_driver_has_gem_prime_res_obj
CONFTEST: drm_atomic_helper_connector_dpms
/var/lib/dkms/nvidia/455.32.00/build/Kbuild:135: recipe for target '/var/lib/dkms/nvidia/455.32.00/build/conftest/compile-tests/drm_atomic_state_ref_counting.h' failed
make[2]: *** [/var/lib/dkms/nvidia/455.32.00/build/conftest/compile-tests/drm_atomic_state_ref_counting.h] Error 139
make[2]: *** Deleting file '/var/lib/dkms/nvidia/455.32.00/build/conftest/compile-tests/drm_atomic_state_ref_counting.h'
make[2]: *** Waiting for unfinished jobs....
Makefile:1757: recipe for target '/var/lib/dkms/nvidia/455.32.00/build' failed
make[1]: *** [/var/lib/dkms/nvidia/455.32.00/build] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-5.4.0-65-generic'
Makefile:81: recipe for target 'modules' failed
make: *** [modules] Error 2
Please tell me what happened and solution.
