Incorrect offset application in NPP ColorTwist conversion
I’m trying to apply a custom conversion matrix to convert NV12 frames to RGB using nppiNV12ToRGB_8u_ColorTwist32f_P2C3R_Ctx with NPP 12.3.
The documentation mention that:
This is how the matrix works for the YUV420/YUV/422/NV12->RGB INVERSE
transform (note- do the offsets first):
  src[0]' = src[0] + aTwist[0][3]
  src[1]' = src[1] + aTwist[1][3]
  src[2]' = src[2] + aTwist[2][3]
And then the remaining 3x3 twist matrix is applied using those modified values:
dst[0] = aTwist[0][0] * src[0]' + aTwist[0][1] * src[1]' + aTwist[0][2] * src[2]'
dst[1] = aTwist[1][0] * src[0]' + aTwist[1][1] * src[1]' + aTwist[1][2] * src[2]'
dst[2] = aTwist[2][0] * src[0]' + aTwist[2][1] * src[1]' + aTwist[2][2] * src[2]'
However it seems that offsets are actually applied after the twist matrix, in the same way they are applied in the reverse transformation:
dst[0] = aTwist[0][0] * src[0] + aTwist[0][1] * src[1] + aTwist[0][2] * src[2] + aTwist[0][3]
dst[1] = aTwist[1][0] * src[0] + aTwist[1][1] * src[1] + aTwist[1][2] * src[2] + aTwist[1][3]
dst[2] = aTwist[2][0] * src[0] + aTwist[2][1] * src[1] + aTwist[2][2] * src[2] + aTwist[2][3]
This is a minimal example to repoduce the issue:
#include <stdio.h>
#include <cuda_runtime.h>
#include <npp.h>
#define SIZE 2
int main(int argc, char** argv) {
    Npp8u* yuv[2];
    int yuv_size[2] = {SIZE * SIZE, (SIZE / 2) * SIZE};
    int yuv_stride[2] = {SIZE, SIZE};
    cudaMalloc((void**) &yuv[0], yuv_size[0] * sizeof(Npp8u));
    cudaMalloc((void**) &yuv[1], yuv_size[1] * sizeof(Npp8u));
    cudaMemset(yuv[0], 128, yuv_size[0] * sizeof(Npp8u));
    cudaMemset(yuv[1], 128, yuv_size[1] * sizeof(Npp8u));
    Npp8u* rgb;
    int rgb_size = SIZE * SIZE * 3;
    int rgb_stride = SIZE;
    cudaMalloc((void**) &rgb, rgb_size * sizeof(Npp8u));
    Npp32f twist[3][4] = {
        {0,0,0,100},
        {0,0,0,0},
        {0,0,0,0},
    NppStreamContext nppStreamCtx;
    nppGetStreamContext(&nppStreamCtx);
    NppiSize roi = {SIZE, SIZE};
    nppiNV12ToRGB_8u_ColorTwist32f_P2C3R_Ctx(yuv, yuv_stride, rgb, rgb_stride, roi, twist, nppStreamCtx);
    Npp8u* rgb_host = (Npp8u*) malloc (rgb_size);
    cudaMemcpy(rgb_host, rgb, rgb_size * sizeof(Npp8u), cudaMemcpyDeviceToHost);
    for (int i = 0; i < SIZE * SIZE; i++) {
        printf("%d) %d %d %d\n", i, rgb_host[i * 3], rgb_host[i * 3 + 1], rgb_host[i * 3 + 2]);
    cudaFree(yuv[0]);
    cudaFree(yuv[1]);
    cudaFree(rgb);
    return 0;
If the offsets are applied before the twist matrix, the resulting RGB matrix should all contain zeros, but instead I get:
 0) 100 0 100
 1) 0 0 100
 2) 0 0 0
 3) 0 0 0
So it looks like the offsets are applied after the multiplications. This makes it impossible to use this function to convert from NV12.
Yep, have just discovered the same problem.
Looks like it’s fixed in NPP v13.0.
