I am using Jetson AGX Xavier kit. It seems that clock is volatile as everytime I turn it on, it shows the icorrect time. Using NTP, I can sync the clock to get the correct time. But I am surprised that it needs to be done at every start up.
BTW, I am using JetPack 4.6 (Ubuntu 18.04 LTS). Below is the other information:
$ ls -l /etc/localtime
lrwxrwxrwx 1 root root 30 Jan 5 15:17 /etc/localtime -> /usr/share/zoneinfo/Asia/Tokyo
$ cat /etc/timezone
Asia/Tokyo
$ timedatectl
Local time: Wed 2023-04-12 14:57:51 JST
Universal time: Wed 2023-04-12 05:57:51 UTC
RTC time: Wed 2023-04-12 05:57:50
Time zone: Asia/Tokyo (JST, +0900)
System clock synchronized: no
systemd-timesyncd.service active: yes
RTC in local TZ: no
$ head -n 1 /etc/nv_tegra_release
# R32 (release), REVISION: 7.3, GCID: 31982016, BOARD: t186ref, EABI: aarch64, DATE: Tue Nov 22 17:32:54 UTC 2022
I suspect that the coin cell shown in the picture below is dead:
You can measure the voltage level of RTC battery when system in power off to make sure if it is dead, and refer to below info from module datasheet.
The following backup cells may be attached to this pin:
Super Capacitor (gold cap, double layer electrolytic)
Standard capacitors (tantalum)
Rechargeable Lithium Manganese cells
The backup cells must provide a voltage in the range 2.5V to 3.5V. These will be charged with a constant current, and a constant voltage charger that can be configured between 2.5V and 3.5V (constant voltage) output and 50 uA to 800 uA (constant current).
During power on, it seems keeping a constant voltage of 2.825V as shown on my multimeter.
I haven’t checked the voltage while it is off.
Surprisingly, not only this but other Jetson are also not displaying the correct time after shutdown.
Is the super capacitor dead in all of my Jetson? I wonder!!! On the other hand, what are the other steps to debug this issue? I have checked the time zone and other information shared above.
Thank you very much for your response. I am sorry for the confusion.
May I request you to please check my first post above. The command timedatectl showed * Wed 2023-04-12 14:57:51 JST* yesterday. I actually shutdown this Jetson on 12 April sometime in afternoon. Yesterday, when I turned it on, it picked up the time from that day.
It seems so. However I haven’t check RTC again. I always notice incorrect date and time on my ubuntu. This behavior is seen on all of my 3-4 Jetson devices.
So far I use NTP to sync the date and time but that was just a workaround. In actual environment, I don’t have internet connection to use NTP or so.
Anyways, can you please tell me the steps to debug the issue further?
No other way than a big battery. Maybe you can use a battery with enough power capacity. The RTC part working current is about 2uA and voltage level is ~3V. You can calculate out backup battery feature based on that.
I turned on my jetson a while ago (April 19th) and executed the timedatectl command. I noticed that the RTC time is also changed. Therefore I decided to inform you to get a green signal to replace the supercapacitor. Please see the output of the command below:
$ timedatectl
Local time: Wed 2023-04-12 11:56:39 JST
Universal time: Wed 2023-04-12 02:56:39 UTC
RTC time: Sat 2000-01-01 01:07:49
RTC in local TZ: no
Please note that my aim is to retain the clock for at least a month (longer is preferred).
