• Hardware (T4/V100/Xavier/Nano/etc)
• Network Type (Detectnet_v2)
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
• Training spec file(If have, please share here)
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
I meet a error when we train lpd model, the log is:
2022-06-28 17:21:39,956 [INFO] root: Registry: ['nvcr.io']
2022-06-28 17:21:40,005 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit-tf:v3.21.11-tf1.15.4-py3
Matplotlib created a temporary config/cache directory at /tmp/matplotlib-u2128em5 because the default path (/.config/matplotlib) is not a writable directory; it is highly recommended to set the MPLCONFIGDIR environment variable to a writable directory, in particular to speed up the import of Matplotlib and to better support multiprocessing.
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
2022-06-28 09:21:48,966 [INFO] root: Building exporter object.
2022-06-28 09:21:50,458 [INFO] root: Exporting the model.
2022-06-28 09:21:50,458 [INFO] root: Using input nodes: ['input_1']
2022-06-28 09:21:50,459 [INFO] root: Using output nodes: ['output_cov/Sigmoid', 'output_bbox/BiasAdd']
2022-06-28 09:21:50,459 [INFO] iva.common.export.keras_exporter: Using input nodes: ['input_1']
2022-06-28 09:21:50,459 [INFO] iva.common.export.keras_exporter: Using output nodes: ['output_cov/Sigmoid', 'output_bbox/BiasAdd']
/usr/local/lib/python3.6/dist-packages/keras/engine/saving.py:292: UserWarning: No training configuration found in save file: the model was *not* compiled. Compile it manually.
warnings.warn('No training configuration found in save file: '
NOTE: UFF has been tested with TensorFlow 1.14.0.
WARNING: The version of TensorFlow installed on this system is not guaranteed to work with UFF.
DEBUG [/usr/local/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py:96] Marking ['output_cov/Sigmoid', 'output_bbox/BiasAdd'] as outputs
2022-06-28 09:21:55,581 [INFO] iva.common.export.keras_exporter: Calibration takes time especially if number of batches is large.
2022-06-28 09:21:55,582 [INFO] root: Calibration takes time especially if number of batches is large.
terminate called after throwing an instance of 'pybind11::error_already_set'
what(): IndexError: tuple index out of range
At:
/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/tensorfile_calibrator.py(75): get_data_from_source
/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/tensorfile_calibrator.py(95): get_batch
/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/export/_tensorrt.py(536): __init__
/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/export/_tensorrt.py(695): __init__
/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/keras_exporter.py(436): export
/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/app.py(247): run_export
/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/export/app.py(265): launch_export
/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/export.py(12): <module>
Aborted (core dumped)
2022-06-28 17:21:59,857 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
2022-06-28 17:59:04,145 [INFO] root: Registry: ['nvcr.io']
2022-06-28 17:59:04,237 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit-tf:v3.21.11-tf1.15.4-py3
Matplotlib created a temporary config/cache directory at /tmp/matplotlib-m5aq1gj7 because the default path (/.config/matplotlib) is not a writable directory; it is highly recommended to set the MPLCONFIGDIR environment variable to a writable directory, in particular to speed up the import of Matplotlib and to better support multiprocessing.
2022-06-28 09:59:12,004 [INFO] root: Building exporter object.
2022-06-28 09:59:13,483 [INFO] root: Exporting the model.
2022-06-28 09:59:13,483 [INFO] root: Using input nodes: ['input_1']
2022-06-28 09:59:13,483 [INFO] root: Using output nodes: ['output_cov/Sigmoid', 'output_bbox/BiasAdd']
2022-06-28 09:59:13,483 [INFO] iva.common.export.keras_exporter: Using input nodes: ['input_1']
2022-06-28 09:59:13,483 [INFO] iva.common.export.keras_exporter: Using output nodes: ['output_cov/Sigmoid', 'output_bbox/BiasAdd']
2022-06-28 09:59:18,624 [INFO] iva.common.export.keras_exporter: Calibration takes time especially if number of batches is large.
2022-06-28 09:59:18,624 [INFO] root: Calibration takes time especially if number of batches is large.
At:
2022-06-28 17:59:22,855 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
