deepstream_test_3.py (13.4 KB)
I have written the script for running the inference on image in python but i am getting the error as shown below while reference script has been added. Please guide. Reference app is considered is : /opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-image-decode-test
diycam@diycam:/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-single_frame$ python3 deepstream_test_3.py /opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_720p.jpg
Creating Pipeline
Creating streamux
Creating source_bin 0
Creating source bin
Creating Pgie
Creating tiler
Creating nvvidconv
Creating nvosd
Creating transform
Creating EGLSink
Adding elements to Pipeline
Linking elements in the Pipeline
Now playing…
1 : /opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_720p.jpg
Starting pipeline
Using winsys: x11
Opening in BLOCKING MODE
ERROR: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-single_frame/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine open error
0:00:04.666064677 19585 0x2879f360 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-single_frame/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:04.666177541 19585 0x2879f360 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-single_frame/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:04.666228998 19585 0x2879f360 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 1]: Trying to create engine from model files
WARNING: INT8 not supported by platform. Trying FP16 mode.
INFO: [TRT]: Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
INFO: [TRT]: Detected 1 inputs and 2 output network tensors.
ERROR: Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine opened error
0:00:46.841647264 19585 0x2879f360 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1743> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:46.987915679 19585 0x2879f360 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 1]: Load new model:dstest3_pgie_config.txt sucessfully
NvMMLiteOpen : Block : BlockType = 277
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 277
Error: gst-stream-error-quark: Internal data stream error. (1): gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstBin:source-bin-00/GstMultiFileSrc:source:
streaming stopped, reason not-linked (-1)
Exiting app
