Inference VGG16 caffe model can not find the output
  • I set the output tensor name is prob
  • error
[E] [TRT] Network must have at least one output
  • parse the caffe model
    const nvcaffeparser1::IBlobNameToTensor* blobNameToTensor = parser->parse(
        Iparams.ParamsCaffe.prototxtFileName.c_str(), Iparams.ParamsCaffe.weightsFileName.c_str(), *network, nvinfer1::DataType::kFLOAT);
    if(!blobNameToTensor)
        std::cout << "can not parse the related files" << std::endl;
        return false;
    for (auto& s : Iparams.ParamsCaffe.outputTensorNames)
        // std::cout << "the output tensor name is " << s << std::endl;
        if(blobNameToTensor->find(s.c_str()))
            network->markOutput(*blobNameToTensor->find(s.c_str()));
        else
            std::cout << "can't not find the output tensor, please check the model output name tensor" << std::endl;
  • the model file VGG_ILSVRC_16_layers_deploy.prototxt . In order to use one batch , I modified input tensor shape from [10,3,224,224] to [1,3,224,224]
input: "data"
input_dim: 1
input_dim: 3
input_dim: 224
input_dim: 224
layers {
  bottom: "data"
  top: "conv1_1"
  type: CONVOLUTION
  convolution_param {
    num_output: 64
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv1_1"
  top: "conv1_1"
  type: RELU
layers {
  bottom: "conv1_1"
  top: "conv1_2"
  type: CONVOLUTION
  convolution_param {
    num_output: 64
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv1_2"
  top: "conv1_2"
  type: RELU
layers {
  bottom: "conv1_2"
  top: "pool1"
  type: POOLING
  pooling_param {
    pool: MAX
    kernel_size: 2
    stride: 2
layers {
  bottom: "pool1"
  top: "conv2_1"
  type: CONVOLUTION
  convolution_param {
    num_output: 128
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv2_1"
  top: "conv2_1"
  type: RELU
layers {
  bottom: "conv2_1"
  top: "conv2_2"
  type: CONVOLUTION
  convolution_param {
    num_output: 128
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv2_2"
  top: "conv2_2"
  type: RELU
layers {
  bottom: "conv2_2"
  top: "pool2"
  type: POOLING
  pooling_param {
    pool: MAX
    kernel_size: 2
    stride: 2
layers {
  bottom: "pool2"
  top: "conv3_1"
  type: CONVOLUTION
  convolution_param {
    num_output: 256
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv3_1"
  top: "conv3_1"
  type: RELU
layers {
  bottom: "conv3_1"
  top: "conv3_2"
  type: CONVOLUTION
  convolution_param {
    num_output: 256
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv3_2"
  top: "conv3_2"
  type: RELU
layers {
  bottom: "conv3_2"
  top: "conv3_3"
  type: CONVOLUTION
  convolution_param {
    num_output: 256
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv3_3"
  top: "conv3_3"
  type: RELU
layers {
  bottom: "conv3_3"
  top: "pool3"
  type: POOLING
  pooling_param {
    pool: MAX
    kernel_size: 2
    stride: 2
layers {
  bottom: "pool3"
  top: "conv4_1"
  type: CONVOLUTION
  convolution_param {
    num_output: 512
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv4_1"
  top: "conv4_1"
  type: RELU
layers {
  bottom: "conv4_1"
  top: "conv4_2"
  type: CONVOLUTION
  convolution_param {
    num_output: 512
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv4_2"
  top: "conv4_2"
  type: RELU
layers {
  bottom: "conv4_2"
  top: "conv4_3"
  type: CONVOLUTION
  convolution_param {
    num_output: 512
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv4_3"
  top: "conv4_3"
  type: RELU
layers {
  bottom: "conv4_3"
  top: "pool4"
  type: POOLING
  pooling_param {
    pool: MAX
    kernel_size: 2
    stride: 2
layers {
  bottom: "pool4"
  top: "conv5_1"
  type: CONVOLUTION
  convolution_param {
    num_output: 512
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv5_1"
  top: "conv5_1"
  type: RELU
layers {
  bottom: "conv5_1"
  top: "conv5_2"
  type: CONVOLUTION
  convolution_param {
    num_output: 512
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv5_2"
  top: "conv5_2"
  type: RELU
layers {
  bottom: "conv5_2"
  top: "conv5_3"
  type: CONVOLUTION
  convolution_param {
    num_output: 512
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv5_3"
  top: "conv5_3"
  type: RELU
layers {
  bottom: "conv5_3"
  top: "pool5"
  type: POOLING
  pooling_param {
    pool: MAX
    kernel_size: 2
    stride: 2
layers {
  bottom: "pool5"
  top: "fc6"
  type: INNER_PRODUCT
  inner_product_param {
    num_output: 4096
layers {
  bottom: "fc6"
  top: "fc6"
  type: RELU
layers {
  bottom: "fc6"
  top: "fc6"
  type: DROPOUT
  dropout_param {
    dropout_ratio: 0.5
layers {
  bottom: "fc6"
  top: "fc7"
  type: INNER_PRODUCT
    num_output: 4096
layers {
  bottom: "fc7"
  top: "fc7"
  type: RELU
layers {
  bottom: "fc7"
  top: "fc7"
  type: DROPOUT
  dropout_param {
    dropout_ratio: 0.5
layers {
  bottom: "fc7"
  top: "fc8"
  type: INNER_PRODUCT
    num_output: 1000
layers {
  bottom: "fc8"
  top: "prob"
  type: SOFTMAX
HI, all
  • I also try use the VGG19 acffe model to inference in the xavier nx . I got the same error
&&&& RUNNING TensorRT.sample_googlenet # ./sample_googlenet
[07/29/2021-10:25:58] [I] Building and running a GPU inference engine for GoogleNet
can not find the tensor named prob
finsh build network
[07/29/2021-10:26:00] [E] [TRT] Network must have at least one output
[07/29/2021-10:26:00] [E] [TRT] Network validation failed.
&&&& FAILED TensorRT.sample_googlenet # ./sample_googlenet
  • use the sampleGoogle code, just change it input caffe model and add some print information in order to help debug.
 * Copyright (c) 2020, NVIDIA CORPORATION. All rights reserved.
 * Licensed under the Apache License, Version 2.0 (the "License");
 * you may not use this file except in compliance with the License.
 * You may obtain a copy of the License at
 *     http://www.apache.org/licenses/LICENSE-2.0
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an "AS IS" BASIS,
 * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 * See the License for the specific language governing permissions and
 * limitations under the License.
//! sampleGoogleNet.cpp
//! This file contains the implementation of the GoogleNet sample. It creates the network using
//! the GoogleNet caffe model.
//! It can be run with the following command line:
//! Command: ./sample_googlenet [-h or --help] [-d=/path/to/data/dir or --datadir=/path/to/data/dir]
#include "argsParser.h"
#include "buffers.h"
#include "common.h"
#include "logger.h"
#include "NvCaffeParser.h"
#include "NvInfer.h"
#include <cuda_runtime_api.h>
#include <cstdlib>
#include <fstream>
#include <iostream>
#include <sstream>
const std::string gSampleName = "TensorRT.sample_googlenet";
//! \brief  The SampleGoogleNet class implements the GoogleNet sample
//! \details It creates the network using a caffe model
class SampleGoogleNet
    template <typename T>
    using SampleUniquePtr = std::unique_ptr<T, samplesCommon::InferDeleter>;
public:
    SampleGoogleNet(const samplesCommon::CaffeSampleParams& params)
        : mParams(params)
    //! \brief Builds the network engine
    bool build();
    //! \brief Runs the TensorRT inference engine for this sample
    bool infer();
    //! \brief Used to clean up any state created in the sample class
    bool teardown();
    samplesCommon::CaffeSampleParams mParams;
private:
    //! \brief Parses a Caffe model for GoogleNet and creates a TensorRT network
    void constructNetwork(
        SampleUniquePtr<nvcaffeparser1::ICaffeParser>& parser, SampleUniquePtr<nvinfer1::INetworkDefinition>& network);
    std::shared_ptr<nvinfer1::ICudaEngine> mEngine{nullptr}; //!< The TensorRT engine used to run the network
//! \brief Creates the network, configures the builder and creates the network engine
//! \details This function creates the GoogleNet network by parsing the caffe model and builds
//!          the engine that will be used to run GoogleNet (mEngine)
//! \return Returns true if the engine was created successfully and false otherwise
bool SampleGoogleNet::build()
    auto builder = SampleUniquePtr<nvinfer1::IBuilder>(nvinfer1::createInferBuilder(sample::gLogger.getTRTLogger()));
    if (!builder)
        return false;
    auto network = SampleUniquePtr<nvinfer1::INetworkDefinition>(builder->createNetwork());
    if (!network)
        return false;
    auto config = SampleUniquePtr<nvinfer1::IBuilderConfig>(builder->createBuilderConfig());
    if (!config)
        return false;
    auto parser = SampleUniquePtr<nvcaffeparser1::ICaffeParser>(nvcaffeparser1::createCaffeParser());
    if (!parser)
        return false;
    constructNetwork(parser, network);
    std::cout << "finsh build network" << std::endl;
    builder->setMaxBatchSize(mParams.batchSize);
    config->setMaxWorkspaceSize(16_MiB);
    // samplesCommon::enableDLA(builder.get(), config.get(), mParams.dlaCore);
    samplesCommon::enableDLA(builder.get(), config.get(), 1);
    mEngine = std::shared_ptr<nvinfer1::ICudaEngine>(
        builder->buildEngineWithConfig(*network, *config), samplesCommon::InferDeleter());
    if (!mEngine)
        return false;
    return true;
//! \brief Uses a caffe parser to create the googlenet Network and marks the
//!        output layers
//! \param network Pointer to the network that will be populated with the googlenet network
//! \param builder Pointer to the engine builder
void SampleGoogleNet::constructNetwork(
        mParams.prototxtFileName.c_str(), mParams.weightsFileName.c_str(), *network, nvinfer1::DataType::kFLOAT);
    for (auto& s : mParams.outputTensorNames)
	else
	    std::cout << "can not find the tensor named " << s << std::endl;
//! \details This function is the main execution function of the sample. It allocates the buffer,
//!          sets inputs and executes the engine.
bool SampleGoogleNet::infer()
    // Create RAII buffer manager object
    samplesCommon::BufferManager buffers(mEngine, mParams.batchSize);
    auto context = SampleUniquePtr<nvinfer1::IExecutionContext>(mEngine->createExecutionContext());
    if (!context)
        return false;
    // Fetch host buffers and set host input buffers to all zeros
    for (auto& input : mParams.inputTensorNames)
        const auto bufferSize = buffers.size(input);
        if (bufferSize == samplesCommon::BufferManager::kINVALID_SIZE_VALUE)
            sample::gLogError << "input tensor missing: " << input << "\n";
            return EXIT_FAILURE;
        memset(buffers.getHostBuffer(input), 0, bufferSize);
    // Memcpy from host input buffers to device input buffers
    buffers.copyInputToDevice();
    bool status = context->execute(mParams.batchSize, buffers.getDeviceBindings().data());
    if (!status)
        return false;
    // Memcpy from device output buffers to host output buffers
    buffers.copyOutputToHost();
    return true;
bool SampleGoogleNet::teardown()
    //! Clean up the libprotobuf files as the parsing is complete
    //! \note It is not safe to use any other part of the protocol buffers library after
    //! ShutdownProtobufLibrary() has been called.
    nvcaffeparser1::shutdownProtobufLibrary();
    return true;
//! \brief Initializes members of the params struct using the command line args
samplesCommon::CaffeSampleParams initializeSampleParams(const samplesCommon::Args& args)
    samplesCommon::CaffeSampleParams params;
    if (args.dataDirs.empty())
        params.dataDirs.push_back("/home/nvidia/workspace/model");
        params.dataDirs.push_back("data/googlenet/");
        params.dataDirs.push_back("data/samples/googlenet/");
        params.dataDirs.push_back("/home/nvidia/tmp/AIOS_frameware_supported_verified");
    else
        params.dataDirs = args.dataDirs;
    // params.prototxtFileName = locateFile("googlenet.prototxt", params.dataDirs);
    // params.weightsFileName = locateFile("googlenet.caffemodel", params.dataDirs);
    // params.prototxtFileName = locateFile("ResNet-50-deploy.prototxt", params.dataDirs);
    // params.weightsFileName = locateFile("ResNet-50-model.caffemodel", params.dataDirs);
    //params.prototxtFileName = locateFile("deploy.prototxt", params.dataDirs);
    //params.weightsFileName = locateFile("bvlc_alexnet.caffemodel", params.dataDirs);
    //params.prototxtFileName = locateFile("VGG_ILSVRC_16_layers_deploy.prototxt", params.dataDirs);
    //params.weightsFileName = locateFile("VGG_ILSVRC_16_layers.caffemodel", params.dataDirs);
    params.prototxtFileName = locateFile("VGG_ILSVRC_19_layers_deploy.prototxt", params.dataDirs);
    params.weightsFileName = locateFile("VGG_ILSVRC_19_layers.caffemodel", params.dataDirs);
    params.inputTensorNames.push_back("data");
    //params.batchSize = 4;
    params.batchSize = 1;
    params.outputTensorNames.push_back("prob");
    params.dlaCore = args.useDLACore;
    return params;
//! \brief Prints the help information for running this sample
void printHelpInfo()
    std::cout
        << "Usage: ./sample_googlenet [-h or --help] [-d or --datadir=<path to data directory>] [--useDLACore=<int>]\n";
    std::cout << "--help          Display help information\n";
    std::cout << "--datadir       Specify path to a data directory, overriding the default. This option can be used "
                 "multiple times to add multiple directories. If no data directories are given, the default is to use "
                 "data/samples/googlenet/ and data/googlenet/"
              << std::endl;
    std::cout << "--useDLACore=N  Specify a DLA engine for layers that support DLA. Value can range from 0 to n-1, "
                 "where n is the number of DLA engines on the platform."
              << std::endl;
int main(int argc, char** argv)
    samplesCommon::Args args;
    bool argsOK = samplesCommon::parseArgs(args, argc, argv);
    if (!argsOK)
        sample::gLogError << "Invalid arguments" << std::endl;
        printHelpInfo();
    if (args.help)
        printHelpInfo();
        return EXIT_SUCCESS;
    auto sampleTest = sample::gLogger.defineTest(gSampleName, argc, argv);
    sample::gLogger.reportTestStart(sampleTest);
    samplesCommon::CaffeSampleParams params = initializeSampleParams(args);
    SampleGoogleNet sample(params);
    sample::gLogInfo << "Building and running a GPU inference engine for GoogleNet" << std::endl;
    if (!sample.build())
        return sample::gLogger.reportFail(sampleTest);
    if (!sample.infer())
    if (!sample.teardown())
    sample::gLogInfo << "Ran " << argv[0] << " with: " << std::endl;
    std::stringstream ss;
    ss << "Input(s): ";
    for (auto& input : sample.mParams.inputTensorNames)
        ss << input << " ";
    sample::gLogInfo << ss.str() << std::endl;
    ss.str(std::string());
    ss << "Output(s): ";
    for (auto& output : sample.mParams.outputTensorNames)
        ss << output << " ";
    return sample::gLogger.reportPass(sampleTest);
  • VGG 19 caffe model is from the caffe offical
  • the protobuf file is just modified the input tensor shape.
input: "data"
input_dim: 1
input_dim: 3
input_dim: 224
input_dim: 224
layers {
  bottom: "data"
  top: "conv1_1"
  type: CONVOLUTION
  convolution_param {
    num_output: 64
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv1_1"
  top: "conv1_1"
  type: RELU
layers {
  bottom: "conv1_1"
  top: "conv1_2"
  type: CONVOLUTION
  convolution_param {
    num_output: 64
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv1_2"
  top: "conv1_2"
  type: RELU
layers {
  bottom: "conv1_2"
  top: "pool1"
  type: POOLING
  pooling_param {
    pool: MAX
    kernel_size: 2
    stride: 2
layers {
  bottom: "pool1"
  top: "conv2_1"
  type: CONVOLUTION
  convolution_param {
    num_output: 128
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv2_1"
  top: "conv2_1"
  type: RELU
layers {
  bottom: "conv2_1"
  top: "conv2_2"
  type: CONVOLUTION
  convolution_param {
    num_output: 128
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv2_2"
  top: "conv2_2"
  type: RELU
layers {
  bottom: "conv2_2"
  top: "pool2"
  type: POOLING
  pooling_param {
    pool: MAX
    kernel_size: 2
    stride: 2
layers {
  bottom: "pool2"
  top: "conv3_1"
  type: CONVOLUTION
  convolution_param {
    num_output: 256
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv3_1"
  top: "conv3_1"
  type: RELU
layers {
  bottom: "conv3_1"
  top: "conv3_2"
  type: CONVOLUTION
  convolution_param {
    num_output: 256
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv3_2"
  top: "conv3_2"
  type: RELU
layers {
  bottom: "conv3_2"
  top: "conv3_3"
  type: CONVOLUTION
  convolution_param {
    num_output: 256
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv3_3"
  top: "conv3_3"
  type: RELU
layers {
  bottom: "conv3_3"
  top: "conv3_4"
  type: CONVOLUTION
  convolution_param {
    num_output: 256
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv3_4"
  top: "conv3_4"
  type: RELU
layers {
  bottom: "conv3_4"
  top: "pool3"
  type: POOLING
  pooling_param {
    pool: MAX
    kernel_size: 2
    stride: 2
layers {
  bottom: "pool3"
  top: "conv4_1"
  type: CONVOLUTION
  convolution_param {
    num_output: 512
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv4_1"
  top: "conv4_1"
  type: RELU
layers {
  bottom: "conv4_1"
  top: "conv4_2"
  type: CONVOLUTION
  convolution_param {
    num_output: 512
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv4_2"
  top: "conv4_2"
  type: RELU
layers {
  bottom: "conv4_2"
  top: "conv4_3"
  type: CONVOLUTION
  convolution_param {
    num_output: 512
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv4_3"
  top: "conv4_3"
  type: RELU
layers {
  bottom: "conv4_3"
  top: "conv4_4"
  type: CONVOLUTION
  convolution_param {
    num_output: 512
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv4_4"
  top: "conv4_4"
  type: RELU
layers {
  bottom: "conv4_4"
  top: "pool4"
  type: POOLING
  pooling_param {
    pool: MAX
    kernel_size: 2
    stride: 2
layers {
  bottom: "pool4"
  top: "conv5_1"
  type: CONVOLUTION
  convolution_param {
    num_output: 512
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv5_1"
  top: "conv5_1"
  type: RELU
layers {
  bottom: "conv5_1"
  top: "conv5_2"
  type: CONVOLUTION
  convolution_param {
    num_output: 512
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv5_2"
  top: "conv5_2"
  type: RELU
layers {
  bottom: "conv5_2"
  top: "conv5_3"
  type: CONVOLUTION
  convolution_param {
    num_output: 512
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv5_3"
  top: "conv5_3"
  type: RELU
layers {
  bottom: "conv5_3"
  top: "conv5_4"
  type: CONVOLUTION
  convolution_param {
    num_output: 512
    pad: 1
    kernel_size: 3
layers {
  bottom: "conv5_4"
  top: "conv5_4"
  type: RELU
layers {
  bottom: "conv5_4"
  top: "pool5"
  type: POOLING
  pooling_param {
    pool: MAX
    kernel_size: 2
    stride: 2
layers {
  bottom: "pool5"
  top: "fc6"
  type: INNER_PRODUCT
    num_output: 4096
layers {
  bottom: "fc6"
  top: "fc6"
  type: RELU
layers {
  bottom: "fc6"
  top: "fc6"
  type: DROPOUT
  dropout_param {
    dropout_ratio: 0.5
layers {
  bottom: "fc6"
  top: "fc7"
  type: INNER_PRODUCT
    num_output: 4096
layers {
  bottom: "fc7"
  top: "fc7"
  type: RELU
layers {
  bottom: "fc7"
  top: "fc7"
  type: DROPOUT
  dropout_param {
    dropout_ratio: 0.5
layers {
  bottom: "fc7"
  top: "fc8"
  type: INNER_PRODUCT
    num_output: 1000
layers {
  bottom: "fc8"
  top: "prob"
  type: SOFTMAX
  • So, did you test the caffe vgg16 or vgg19 model in the device?
I find a new caffe model prototxt file. it works in my device. I’m very confused why it works
input: "data"
input_dim: 2
input_dim: 3
input_dim: 224
input_dim: 224
layer {
  bottom: "data"
  top: "conv1_1"
  type: "Convolution"
  convolution_param {
    num_output: 64
    pad: 1
    kernel_size: 3
layer {
  bottom: "conv1_1"
  top: "conv1_1"
  type: "ReLU"
layer {
  bottom: "conv1_1"
  top: "conv1_2"
  type: "Convolution"
  convolution_param {
    num_output: 64
    pad: 1
    kernel_size: 3
layer {
  bottom: "conv1_2"
  top: "conv1_2"
  type: "ReLU"
layer {
  bottom: "conv1_2"
  top: "pool1"
  type: "Pooling"
  pooling_param {
    pool: MAX
    kernel_size: 2
    stride: 2
layer {
  bottom: "pool1"
  top: "conv2_1"
  type: "Convolution"
  convolution_param {
    num_output: 128
    pad: 1
    kernel_size: 3
layer {
  bottom: "conv2_1"
  top: "conv2_1"
  type: "ReLU"
layer {
  bottom: "conv2_1"
  top: "conv2_2"
  type: "Convolution"
  convolution_param {
    num_output: 128
    pad: 1
    kernel_size: 3
layer {
  bottom: "conv2_2"
  top: "conv2_2"
  type: "ReLU"
layer {
  bottom: "conv2_2"
  top: "pool2"
  type: "Pooling"
  pooling_param {
    pool: MAX
    kernel_size: 2
    stride: 2
layer {
  bottom: "pool2"
  top: "conv3_1"
  type: "Convolution"
  convolution_param {
    num_output: 256
    pad: 1
    kernel_size: 3
layer {
  bottom: "conv3_1"
  top: "conv3_1"
  type: "ReLU"
layer {
  bottom: "conv3_1"
  top: "conv3_2"
  type: "Convolution"
  convolution_param {
    num_output: 256
    pad: 1
    kernel_size: 3
layer {
  bottom: "conv3_2"
  top: "conv3_2"
  type: "ReLU"
layer {
  bottom: "conv3_2"
  top: "conv3_3"
  type: "Convolution"
  convolution_param {
    num_output: 256
    pad: 1
    kernel_size: 3
layer {
  bottom: "conv3_3"
  top: "conv3_3"
  type: "ReLU"
layer {
  bottom: "conv3_3"
  top: "conv3_4"
  type: "Convolution"
  convolution_param {
    num_output: 256
    pad: 1
    kernel_size: 3
layer {
  bottom: "conv3_4"
  top: "conv3_4"
  type: "ReLU"
layer {
  bottom: "conv3_4"
  top: "pool3"
  type: "Pooling"
  pooling_param {
    pool: MAX
    kernel_size: 2
    stride: 2
layer {
  bottom: "pool3"
  top: "conv4_1"
  type: "Convolution"
  convolution_param {
    num_output: 512
    pad: 1
    kernel_size: 3
layer {
  bottom: "conv4_1"
  top: "conv4_1"
  type: "ReLU"
layer {
  bottom: "conv4_1"
  top: "conv4_2"
  type: "Convolution"
  convolution_param {
    num_output: 512
    pad: 1
    kernel_size: 3
layer {
  bottom: "conv4_2"
  top: "conv4_2"
  type: "ReLU"
layer {
  bottom: "conv4_2"
  top: "conv4_3"
  type: "Convolution"
  convolution_param {
    num_output: 512
    pad: 1
    kernel_size: 3
layer {
  bottom: "conv4_3"
  top: "conv4_3"
  type: "ReLU"
layer {
  bottom: "conv4_3"
  top: "conv4_4"
  type: "Convolution"
  convolution_param {
    num_output: 512
    pad: 1
    kernel_size: 3
layer {
  bottom: "conv4_4"
  top: "conv4_4"
  type: "ReLU"
layer {
  bottom: "conv4_4"
  top: "pool4"
  type: "Pooling"
  pooling_param {
    pool: MAX
    kernel_size: 2
    stride: 2
layer {
  bottom: "pool4"
  top: "conv5_1"
  type: "Convolution"
  convolution_param {
    num_output: 512
    pad: 1
    kernel_size: 3
layer {
  bottom: "conv5_1"
  top: "conv5_1"
  type: "ReLU"
layer {
  bottom: "conv5_1"
  top: "conv5_2"
  type: "Convolution"
  convolution_param {
    num_output: 512
    pad: 1
    kernel_size: 3
layer {
  bottom: "conv5_2"
  top: "conv5_2"
  type: "ReLU"
layer {
  bottom: "conv5_2"
  top: "conv5_3"
  type: "Convolution"
  convolution_param {
    num_output: 512
    pad: 1
    kernel_size: 3
layer {
  bottom: "conv5_3"
  top: "conv5_3"
  type: "ReLU"
layer {
  bottom: "conv5_3"
  top: "conv5_4"
  type: "Convolution"
  convolution_param {
    num_output: 512
    pad: 1
    kernel_size: 3
layer {
  bottom: "conv5_4"
  top: "conv5_4"
  type: "ReLU"
layer {
  bottom: "conv5_4"
  top: "pool5"
  type: "Pooling"
  pooling_param {
    pool: MAX
    kernel_size: 2
    stride: 2
layer {
  bottom: "pool5"
  top: "fc6"
  type: "InnerProduct"
    num_output: 4096
layer {
  bottom: "fc6"
  top: "fc6"
  type: "ReLU"
layer {
  bottom: "fc6"
  top: "fc6"
  type: "Dropout"
  dropout_param {
    dropout_ratio: 0.5
layer {
  bottom: "fc6"
  top: "fc7"
    num_output: 4096
layer {
  bottom: "fc7"
  top: "fc7"
  type: "ReLU"
layer {
  bottom: "fc7"
  top: "fc7"
  type: "Dropout"
  dropout_param {
    dropout_ratio: 0.5
layer {
  bottom: "fc7"
  top: "fc8"
    num_output: 1000
layer {
  bottom: "fc8"
  top: "prob"
  type: "Softmax"
We do test VGG on Jetson in our benchmark.
The model we used can be downloaded with the below command:
$ wget https://www.dropbox.com/s/t4qq079g5q4jibx/vgg19_N2.prototxt
The problem with this error is that we only support the original prototxt definition.
Please convert the file into the supported version to fix this issue.
For example, please convert
layers {
  bottom: "data"
  top: "conv1_1"
  type: CONVOLUTION
  convolution_param {
    num_output: 64
    pad: 1
    kernel_size: 3
into
layer {
  bottom: "data"
  top: "conv1_1"
  type: "Convolution"
  convolution_param {
    num_output: 64
    pad: 1
    kernel_size: 3
