InfiniBand bridging in BlueField-2
I have a simple question.
Can I use BlueField-2 to bridge InfiniBand traffic between Host and ARM when operating in Embedded Mode?
If not, what is the main benefit of using BF-2 in InfiniBand with Embedded Mode?
Hi Jongwook,
​Do you mean you want to set BlueField-2 as ECPF mode (Embedded CPU Function Ownership Mode (SmartNIC Mode)) ?
Simple answer for your question is Yes.
Here is more information below:​
Currently, BlueField-2 DPU supports configuring network ports as either Ethernet only or InfiniBand only.
In ECPF mode, the NIC resources and functionality are owned and controlled by the embedded Arm subsystem. A network function is still exposed to the host.
There are two ways to pass traffic to the host interface:
1)Either using representors to forward traffic to the host (every packet to/from the host would be handled also by the network interface on the embedded Arm side),
2)or push rules to the embedded switch which allows and offloads this traffic.
Regards,​
Levei
