Initializing media entity for camera sensor
I am trying to add support for a new v4l2 camera sensor in 24.2.
I have created a new device tree entry for the sensor and linked it to vi port 0. My sensor driver probe routine is being called and i am initializing it as a media entity as follows
priv->pad.flags = MEDIA_PAD_FL_SOURCE;
	priv->subdev.entity.type = MEDIA_ENT_T_V4L2_SUBDEV_SENSOR;
	ret = media_entity_init(&priv->subdev.entity, 1, &priv->pad, 0);
	if (ret < 0) {
		dev_err(&client->dev, "unable to init media entity\n");
		return ret;
sd->dev = &client->dev;
ret = v4l2_async_register_subdev(sd);
if (!ret)
	v4l2_info(&priv->subdev, "%s camera sensor driver registered\n", &priv->subdev.name);
There are no errors during this process and i see in the logs the successful camera sensor driver registered message.
However when i check the media devices using media-ctl -p i only see the vi-output-0 device. My sensor does not show up.
Media controller API version 0.1.0
Media device information
driver          vi
model           NVIDIA Tegra Video Input Device
serial
bus info
hw revision     0x3
driver version  0.0.0
Device topology
- entity 1: vi-output-0 (1 pad, 0 link)
            type Node subtype V4L flags 0
            device node name /dev/video0
        pad0: Sink
Any ideas on where to look to further debug this problem?
I tried to build media-ctl on TX1(GitHub - fastr/media-ctl: fsr fork of git://git.ideasonboard.org/media-ctl.git ?), but got compilation failure.
You can use the following commands to list the v4l2 devices and check the compliance,
v4l2-ctl --list-devices
	v4l2-compliance -d /dev/video0
