Input multiple images on deepstream-app
Hi, I’m testing out the object detection deepstream-app samples. I can see that the deepstream_app_config_yolo[…].txt has a MultiURI option in the [source0] stanza. Can it be used to specify multiple images as inputs?
YES. We also have example to demonstrate image decoding instead of video.
/opt/nvidia/deepstream/deepstream-4.0/sources/apps/sample_apps/deepstream-image-decode-test/
Thanks - but the same input format doesn’t seem to work for the Yolo demo:
deepstream-app -c deepstream_app_config_yoloV3.txt -i /home/tx2/Documents/YoloV3/obj/IMG_0693.jpg
will work. But this won’t:
deepstream-app -c deepstream_app_config_yoloV3.txt -i /home/tx2/Documents/YoloV3/obj/IMG_0693.jpg /home/tx2/Documents/YoloV3/obj/IMG_0694.jpg
The config file is set to MultiURI.
Sorry for the late update.
You will need to use the deepstream-image-decode-app rather than deepstream-app.
For example:
$ ./deepstream-image-decode-app <file1> [file2] ... [fileN]
$ ./deepstream-image-decode-app file1.mjpeg file2.mjpeg
How do I save the inferenced image from the deepstream-image-decode-app?
I ran the image-decode-app and it display the inferenced image for less than 1 second, and disappears ans also tried adding
in the config file, and nothing happend.
Can you help on this?
Hello jayrodge, have you solved this problem?
Not yet @1456873666
Hey man!
Have you managed to solve this ? I am also wondering about that.
