"Input/output error" when using cuda-gdb ?
Hello, I got a question while using cuda-gdb
when I stepped into one kernel function and set breakpoint, it returned info:
Warning:
Cannot insert breakpoint 4.
Error accessing memory address 0xd8: Input/output error.
cuda-gdb used to work before, but when I modified the code(pad zeros to global memory)
it always showed the “I/O” error??
(cuda-gdb) s
Warning:
Cannot insert breakpoint 0.
Error accessing memory address 0x0: Input/output error.
Have a similar problem, cannot believe there is no replay!?
Wow, that sounds serious. Can you paste your code?
