Hi!
Last week I forgot to fill a CHARACTER*4 with the year ‘2008’.
As a result, the directory where my application was looking for its input
was a bogus string containing two consecutive slashes and which obviously did not exist.
Nevertheless, INQUIRE tells me that that file does exist and my program proceeds and crashes trying to read it…
Below you’ll find a narrowed down piece of code.
If you replace the part '/home/dijkva/'by an existing directory
on your machine, then you’ll probably get the same result as I get:
the first attempt via the main program tells you that ‘myfile’ does not exist.
The second attempt however suggests successful probing!
I am running:
pgf90 6.1-4 32-bit target on x86-64 Linux
Copyright 1989-2000, The Portland Group, Inc. All Rights Reserved.
Copyright 2000-2006, STMicroelectronics, Inc. All Rights Reserved.
I did not use any fancy compile-switches. Just “pgf90”.
Is this a bug in the compiler?
When compiled with e.g. g95 both calls tell me that the file does not exist.
Regards,
Arjan
MODULE LibUtil
IMPLICIT NONE
PRIVATE
PUBLIC :: FileExists,MyRoutine
CONTAINS
FUNCTION FileExists(Directory,FName)
CHARACTER(*), INTENT(INOUT) :: FName,Directory
LOGICAL :: FileExists,DumLog
CHARACTER(256) :: MyString
MyString = TRIM(Directory)//TRIM(FName)
WRITE(*,'(A)') 'Just before it happens... "'//TRIM(MyString)//'"'
INQUIRE(FILE=TRIM(MyString),EXIST=DumLog)
FileExists = DumLog
END FUNCTION FileExists
SUBROUTINE MyRoutine()
CHARACTER(256) :: FName,Directory
LOGICAL :: DumLog
CHARACTER :: YearStr*4
FName = 'myfile'
! WRITE(YearStr,'(I4)') 2008 ! this is the line that I forgot to code...
Directory = '/home/dijkva/' // YearStr // '/'
DumLog = FileExists(Directory,FName)
WRITE(*,*) DumLog
END SUBROUTINE MyRoutine
END MODULE LibUtil
PROGRAM Test
USE libutil
IMPLICIT NONE
CHARACTER(256) :: Directory,FName
LOGICAL :: DumLog
Directory = '/home/dijkva//'
FName = 'myfile'
WRITE(*,*) DumLog
CALL MyRoutine()
END PROGRAM Test
[/code]
