Hello everyone:
Today I encountered a problem.
First of all, I have two files, File1.dat includes the name of another file File2.dat.
Content of File1.dat:
./File2.dat
I use a character variable to read the file name in File1.dat such as:
CHARACTER(LEN=1024) :: filename
OPEN( UNIT = 100 , FILE = ‘File1.dat’ , STATUS = ‘OLD’ )
READ(100,’(A1024)’) filename
CLOSE(100)
And then I want to use filename to open the second file:
OPEN ( UNIT = 101 , FILE = TRIM(filename) , STATUS=‘OLD’ )
But I got an error:
FIO-F-209/OPEN/unit=101/‘OLD’ specified for file which does not exist.
File name = ./File2.dat
In source file main.f90, at line number 855
The same main.f90 can execute correctly if I use intel fortran compiler on my PC.
But the cluster only provide PGI compiler.
Did any one have the same problem?
Thanks in advance.
Hi Rex K-S Liu,
Does the file exist in the local directory? If so can you please post a reproducing example of the failing code and more information about the system (i.e are you using Linux? x86? Power?) and the compiler version?
I tried to write a reproducer, but I’m not able to recreate the error.
% cat test.F90
program foo
integer :: val
OPEN( UNIT = 100 , FILE = 'File1.dat' , STATUS = 'OLD' )
READ(100,'(A1024)') filename
CLOSE(100)
OPEN ( UNIT = 101 , FILE = TRIM(filename) , STATUS='OLD' )
READ(101,'(I)') val
close(101)
print *, val
end program foo
% pgfortran -fast -V18.4 test.F90
% cat File1.dat
./File2.dat
% cat File2.dat
100
% a.out
100
-Mat
Hi Mat
Thanks for your reply.
As you did, I test a smaller program and it worked well.
But my original program is large.
The following is the essential part which produced the problem.
Also, contents of the file input.dat are shown below.
My PC:
OS : CentOS Linux release 7.5.1804
PGI version : PGI 17.10 community
Thanks for your help!!
MODULE DoublePrecision
IMPLICIT NONE
INTEGER,PARAMETER :: DP = SELECTED_REAL_KIND( P=15 )
END MODULE DoublePrecision
MODULE fileIndex
IMPLICIT NONE
INTEGER,PARAMETER :: IO1 = 101 ! input.dat
INTEGER,PARAMETER :: IO2 = 102 ! body file
END MODULE fileIndex
MODULE IBMPar
USE DoublePrecision
IMPLICIT NONE
! nBody : number of bodies
INTEGER :: nBody
! BodyPar : variable type of a body
TYPE BodyPar
! fileName : file name of the body data
CHARACTER(LEN=1024) :: fileName
! disX, disY : displacement vector of the original body
REAL(KIND=DP) :: disX, disY
! nMesh : number of grids of the body
INTEGER :: nGrid
! xG, yG : coordinates of the body grids
REAL(KIND=DP),DIMENSION(:),ALLOCATABLE :: xG, yG
END TYPE BodyPar
TYPE(BodyPar),DIMENSION(:),ALLOCATABLE :: IBBody
END MODULE IBMPar
PROGRAM MAIN
IMPLICIT NONE
! fileIn =========================================================================
CALL fileIn()
END PROGRAM MAIN
SUBROUTINE fileIn()
USE fileIndex
USE IBMPar
IMPLICIT NONE
! local variable =================================================================
INTEGER :: i, j
! open input.dat =================================================================
OPEN( UNIT = IO1 , FILE = 'input.dat' , STATUS = 'OLD' )
READ(IO1,*) nBody
ALLOCATE( IBBody(nBody) )
DO i = 1 , nBody
READ(IO1,'(A1024)') IBBody(i)%fileName
READ(IO1,*) IBBody(i)%disX, IBBody(i)%disY
ENDDO
CLOSE(IO1)
! read body files ================================================================
CALL IBM_BodyIn()
RETURN
END SUBROUTINE fileIn
SUBROUTINE IBM_BodyIn()
USE fileIndex
USE IBMPar
IMPLICIT NONE
! local variables =====================================================================
INTEGER :: i, j
DO i = 1 , nBody
OPEN( UNIT = IO2 , FILE = TRIM(IBBody(i)%fileName) , STATUS = 'OLD' )
READ(IO2,*) IBBody(i)%nGrid
ALLOCATE( IBBody(i)%xG(IBBody(i)%nGrid) , IBBody(i)%yG(IBBody(i)%nGrid) )
DO j = 1 , IBBody(i)%nGrid
READ(IO2,*) IBBody(i)%xG(j) , IBBody(i)%yG(j)
ENDDO
IBBody(i)%xG = IBBody(i)%xG + IBBody(i)%disX
IBBody(i)%yG = IBBody(i)%yG + IBBody(i)%disY
CLOSE(IO2)
ENDDO
RETURN
END SUBROUTINE IBM_BodyIn
4 nBody number of geometry files
./SCCS/text1.dat
5.0 6.5
./SCCS/text2.dat
7.0 6.5
./SCCS/text3.dat
9.0 6.5
./SCCS/text4.dat
11.0 6.5
One way this could happen is if “input1.txt” was created on a Window’s system in which case the text file uses different characters for newlines.
For example, if I use Notepad on Windows to create “File1.dat”, I can recreate your error using my little test program:
% a.out
FIO-F-209/OPEN/unit=101/'OLD' specified for file which does not exist.
File name = ./SCCS/File2.dat
In source file test.F90, at line number 10
Running the “dos2unix” utility on the file to convert the newline characters to UNIX style, fixes the issue:
% a.out
% dos2unix File1a.dat
dos2unix: converting file File1a.dat to Unix format ...
% a.out
100
How was your “input1.txt” file created? Could something similar be happening here?
-Mat
Hi Mat
Yes my *.dat files were created in Windows PC.
And the command dos2unix works well.
Rex
