Trying to install 10.2 on RHEL 8 system. I downloaded cuda-repo-rhel8-10-2-local-10.2.89-440.33.01-1.0-1.x86_64.rpm, installed it. When I run the command dnf -y module install nvidia-driver:latest-dkms I receive the error message: module yaml error: Artifact ‘cuda-0:drivers-440.33.01-1.x86_64’ was not in valid N-E:V-R.A format. I re-downloaded the software just in case of corruption and same issue. I was able to install 11.8 but need to run with 10.2 for compatibility of software I will be running on the system.
Related topics
| Cuda 10.2 (driver 440) fails to install in RHEL 8.8 | 0 | 611 | August 2, 2023 | |
| No NVIDIA driver kernel module package kmod-nvidia-450 | 1 | 4402 | July 28, 2020 | |
| Unable to load nvidia module on Red Hat Enterprise Linux 8.0 and 8.1 | 0 | 1098 | February 21, 2020 | |
| Cherry Pick cuda-rhel8.repo for version 570 | 1 | 152 | June 10, 2025 | |
| Unable to load NVIDIA System Management Interface due to Driver on RHEL 8 | 0 | 379 | December 21, 2020 | |
| NVIVIA driver install for a fully patched RHEL 8 fails | 2 | 1780 | January 17, 2023 | |
| CUDA install issue on Centos 8 | 4 | 3155 | July 14, 2022 | |
| Unable to set up cuda-8.0 on RHEL 7.4 | 5 | 2147 | February 1, 2018 | |
| Can not install cuda-10.2, please help, thank you | 0 | 633 | June 20, 2020 | |
| Can not install cuda-10.2, please help, thank you | 0 | 1484 | June 20, 2020 |
