@jaai0123210 Amazingly, I cannot run cuDNN on WSL2 directly, but I can run CuDNN inside docker containers inside WSL2.
In WSL2 Install the package docker.io (! important, not docker but docker.io !) and nvidia-container-toolkit (this is required for docker run --gpus to work)
then set up a docker container like
mkdir mountdir;
docker run --gpus all -dit \
-e DISPLAY=$DISPLAY \
-v /tmp/.X11-unix:/tmp/.X11-unix \
--network=host \
--shm-size=5g \
--name "${CONTAINER_NAME}" \
-v "${MOUNT_DIR}":/mountdir \
ubuntu:24.04 bash
docker exec -i "${CONTAINER_NAME}" bash <<'EOF'
set -eux
export DEBIAN_FRONTEND=noninteractive
apt update;
apt full-upgrade -y;
apt install tzdata;
ln -fs /usr/share/zoneinfo/Europe/Oslo /etc/localtime
echo "Europe/Oslo" > /etc/timezone
dpkg-reconfigure -f noninteractive tzdata;
apt install screen screenie nano vim sudo wget curl htop php-cli python3 python-is-python3 python3-venv git build-essential cmake python3-dev -y;
wget https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2404/x86_64/cuda-keyring_1.1-1_all.deb;
dpkg -i cuda-keyring_1.1-1_all.deb;
apt update;
apt -y install cuda-toolkit-12-9;
apt -y install cudnn;
echo 'export PATH="/usr/local/cuda-12.9/bin:$PATH"' >> ~/.bashrc;
echo 'export LD_LIBRARY_PATH="/usr/local/cuda-12.9/lib64:$LD_LIBRARY_PATH"' >> ~/.bashrc;
echo 'export CUDA_HOME="/usr/local/cuda-12.9"' >> ~/.bashrc;
mkdir -p /root/.local/venv;
python3 -m venv /root/.local/venv;
echo 'source /root/.local/venv/bin/activate;' >> ~/.bashrc;
EOF
Then access the container like
docker exec -it "${CONTAINER_NAME}" bash
and.. inside that container,
cudnn works great!
and nvtop works great!
and python AI libraries work great!
But it does not work outside docker containers (wtf?)
Fwiw here is the exact setup that works for me:
hans@DESKTOP-EE15SLU:~/projects/rembg_model$ cat docker.sh
#!/bin/bash
set -eux
CONTAINER_NAME="rembg_model_trainer"
# Get script directory
SCRIPT_DIR="$(cd "$(dirname "${BASH_SOURCE[0]}")" && pwd)"
cd "${SCRIPT_DIR}"
# Create mount directory if it does not exist
MOUNT_DIR="$(pwd)";
mkdir -p "${MOUNT_DIR}"
# Check if the container exists
if docker ps -a --format '{{.Names}}' | grep -q "^${CONTAINER_NAME}$"; then
# Check if the container is running
if docker ps --format '{{.Names}}' | grep -q "^${CONTAINER_NAME}$"; then
echo "Container '${CONTAINER_NAME}' is already running. Attaching..."
else
echo "Container '${CONTAINER_NAME}' exists but is not running. Starting and attaching..."
docker start -ai "${CONTAINER_NAME}"
fi
else
# Run the container in detached mode
#-p 7011:7011/tcp -p 7011:7011/udp \
--network=host \
--shm-size=5g \
ubuntu:24.04 bash
echo "Running initialization steps..."
set -eux
apt update;
apt install tzdata;
apt update;
wget 'https://raw.githubusercontent.com/divinity76/bashrc/refs/heads/master/install.sh' -O- | bash
#source ~/.bashrc;
pip install --upgrade pip;
#pip install torch torchvision torchaudio --index-url https://download.pytorch.org/whl/cu128 --upgrade;
#cat /root/.bashrc > /home/ubuntu/.bashrc;
#cat /root/.hansrc > /home/ubuntu/.hansrc;
#cat /root/.bash_aliases > /home/ubuntu/.bash_aliases;
cd /mountdir/training/U-2-Net;
sed 's/=.*//' requirements.txt > requirements.tmp
mv requirements.tmp requirements.txt
pip install -r requirements.txt;
EOF
fi
i run
bash docker.sh
every time i want to access the docker container.
but it includes stuff like
which you probably don’t want (it’s my personal bash init script, configuring bash to my personal preferences),
and that script adds to .bashrc stuff like
if [[ ! "$PATH" =~ "$HOME/.local/bin" ]]; then
if [[ -d "$HOME/.local/bin" ]]; then
export PATH="$HOME/.local/bin:$PATH"
fi
fi
# activate virtualenv if it exists and isn't already activated
if [[ -z "$VIRTUAL_ENV" ]]; then
if [[ -f "$HOME/.local/venv/bin/activate" ]]; then
VIRTUAL_ENV_DISABLE_PROMPT=1 source "$HOME/.local/venv/bin/activate"
fi
fi
which might be relevant to getting it to work.
