How to install Cudnn on Ubuntu WSL2?
I have encountered an issue running Tensorflow 2 on my Windows 10 (it only runs one epoch), so I am trying to install cuda and tensorflow 2 on Ubuntu via WSL2 instead.
I have followed this guide:
which is very similar to the Nvidia one here, only I have installed cuda version 11.4 instead of the latest cuda 11.7:
I am stuck if I need to install cuDNN after this and what version. Windows or Linux in my case (NVIDIA cuDNN Installation Guide — NVIDIA cuDNN Installation)?
do I need a local installer for Ubuntu 20.04 x86_64(Deb) or a local installer for Linux x86_64 (Tar), for CUDA 11.x] of cuDNN v8.4.1 (March 27th, 2022) from NVIDIA cuDNN Installation Guide — NVIDIA cuDNN Installation?
when I run my notebook, I get the following issue, which shows cuDNN is missing:
> physical_devices = tf.config.list_physical_devices('GPU')
> physical_devices
> 2022-06-03 18:30:28.966198: W tensorflow/stream_executor/platform/default/dso_loader.cc:64] Could not load dynamic library 'libcudnn.so.8'; dlerror: libcudnn.so.8: cannot open shared object file: No such file or directory
> 2022-06-03 18:30:28.966233: W tensorflow/core/common_runtime/gpu/gpu_device.cc:1850] Cannot dlopen some GPU libraries. Please make sure the missing libraries mentioned above are installed properly if you would like to use GPU. Follow the guide at https://www.tensorflow.org/install/gpu for how to download and setup the required libraries for your platform.
> Skipping registering GPU devices...
My specs:
Ubuntu 20.04 via WSL2
Windows 10 21H2
Nvidia latest driver, 512.95 compatible with GeForce RTX 3060
Cuda Driver Version/ Runtime Version 11.6/11.4( can update this to 11.7?)
Tensorflow 2.9.1
Python 3.9.7.
Please advise on how to proceed?
