Windows 11, rtx 4070 error installing cudnn/tensorflow
i have cudnn 8.8.1.3 installed as well as cuda 12.1.0_531.14
i’m following the steps from tensorflow on windows-wsl2 :
python -m pip install nvidia-cudnn-cu11==8.6.0.163 tensorflow==2.12.*
gives me an error:
Looking in indexes: https pypi org simple, https pypi ngc nvidia com (edit: link removed, can’t paste it here)
ERROR: Could not find a version that satisfies the requirement nvidia-cudnn-cu11==8.6.0.163 (from versions: 0.0.1.dev5, 2021.10.26, 2021.11.18, 2021.12.8, 2022.1.13, 2022.4.2, 2022.5.19)
ERROR: No matching distribution found for nvidia-cudnn-cu11==8.6.0.163
same if i change version to 8.8.1.3
I’m trying to install cudnn version 8.6.0.163 and am getting the same error. The error also happens for other versions. I’m on Windows 11, RTX 3060.
When I run pip install nvidia-cudnn-cu11 I get:
Looking in indexes: https://pypi.org/simple, https://pypi.ngc.nvidia.com
Collecting nvidia-cudnn-cu11
  Downloading https://developer.download.nvidia.com/compute/redist/nvidia-cudnn-cu11/nvidia-cudnn-cu11-2022.5.19.tar.gz (16 kB)
  Preparing metadata (setup.py) ... done
Collecting nvidia-cudnn-cu116
  Downloading nvidia-cudnn-cu116-0.0.1.dev5.tar.gz (4.4 kB)
  Preparing metadata (setup.py) ... error
  error: subprocess-exited-with-error
  × python setup.py egg_info did not run successfully.
  │ exit code: 1
  ╰─> [17 lines of output]
        File "<string>", line 2, in <module>
        File "<pip-setuptools-caller>", line 34, in <module>
        File "C:\Users\mallo\AppData\Local\Temp\pip-install-b6w1lra5\nvidia-cudnn-cu116_43c376fad8fd4c15b8b5516f5eaa4c32\setup.py", line 152, in <module>
          raise RuntimeError(open("ERROR.txt", "r").read())
      RuntimeError:
      The package you are trying to install is only a placeholder project on PyPI.org repository.
      This package is hosted on NVIDIA Python Package Index.
      This package can be installed as:
      $ pip install nvidia-pyindex
      $ pip install nvidia-cudnn-cu116
      [end of output]
  note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
Does anyone know how to solve this? Thanks.
There is an issue with tensorflow >=2.11. This solved my problem:
Wish you luck!
I have the problem too. Even with WSL 2 installed on Windows 11. The step that fails is when trying to install cudnn as described in the TensorFlow docs. But I am not convinced that this is a TensorFlow installation issue.
Command I issued:
Error:
This is happening, before TensorFlow is installed. nvidia-cudnn-cu11 is mainTained by nvidia, SEE nvidia-cudnn-cu11 · PyPI
same issue, bother me a lot
