New to gpu computing, have installed a gtx 1660ti with compute capability of 7.5. I’m using on ubuntu 21.10, have set up nvidia-toolkit, cudnn, tensorflow, tensorflow-gpu in a conda env, all appears to work fine: 1 gpu visible, built with cudnn 11.6.r11.6, tf version 2.8.0, python version 3.7.10 all in conda env running on a jupyter notebook. All seems to run fine until I attempt to train a model and then I get this error message:
2022-03-19 04:42:48.005029: I tensorflow/stream_executor/cuda/cuda_dnn.cc:368] Loaded cuDNN version 8302
and then the kernel just locks up and crashes. BTW the code worked prior to installing gpu, when it simply used cpu. Is this simply a version mismatch somewhere between python, tensorflow, tensorflow-gpu, cudnn versions or something more sinister? Thx. J.
Hi, I have the exactly same problem, I am using tensorflow 2.8.0 with CudNN 11.2 and python 3.7.6 with one GPU visible. The code also worked before I set up the Toolkits and and environment variables, but now it crashes after the same message.
2022 15:45:05.860344: I tensorflow/stream_executor/cuda/cuda_dnn.cc:368] Loaded cuDNN version 8400
I would really appreciate if some one could help out with this issue, or maybe if @jimmaasuk you have found a solution for this problem,
I have the same problem, the environment is py3.8.10 tf2.8 keras 2.8 output log: Epoch 1 / 30 2022-04-23 11:25:22.138221: I tensorflow/stream_executor/cuda/cuda_dnn.cc: 368] Loaded cuDNN version 8400,
Hallo,
I had the same issue, although I do not know how to fix the problem, I have downgraded to tensorflow and keras 2.4.0 and to CUDA version 11.0 and cuDNN 8.0 and now I can finally work without issues.
Best luck
