I need to use DeepStream Triton Server. For that purpose currently I am using DeepStream Triton container. But, I have another container that contains all other project related dependencies. So, I need to install all the dependencies needed to run nvinferserver on that container.
Can you please specify what dependencies I need to install for that and from where I can install them in the container?
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
