Which deepstream 6.4 docker image should be used
• DeepStream Version
• TensorRT Version
I want to migrate from my deepstream 6.1.1 to deepstream6.4
which docker image should I consider, I am not using the triton server client
Triton devel docker (contains the entire SDK along with a development environment for building DeepStream applications and graph composer) docker pull nvcr.io/nvidia/deepstream:6.4-gc-triton-devel
Triton Inference Server docker with Triton Inference Server and dependencies installed along with a development environment for building DeepStream applications docker pull nvcr.io/nvidia/deepstream:6.4-triton-multiarch
Which docker are you using in DeepStream 6.1.1? If you use 6.1.1-samples, you can use 6.4-samples-multiarch, and if you use -dev docker, you can use 6.4-gc-triton-devel.
thanks!
I am unable to run the python code that I was able to execute on deppstream-6.1.1
Please run the “/opt/nvidia/deepstream/deepstream/user_deepstream_python_apps_install.sh” script to install pyds.
The command line is /opt/nvidia/deepstream/deepstream/user_deepstream_python_apps_install.sh --version 1.1.10
what version is this?
It is the tag for NVIDIA-AI-IOT/deepstream_python_apps at v1.1.10 (github.com)
