Hi, I just bought Jetson TX2, and Im wondering whether I can Install Image Recognition on Jetson TX2 without any HOST PC? Or Do I need to use Host PC to be able to run Image Recognition on Jetson TX2? As I read, that for running Image Recognition, I would need to Install DIGITS too. Can I install both of those in my Jetson TX2 without any Host PC?
Note : I wont need all the sub class of image recognition dataset (which is 100GB), I will only need specific subclass.
Thx
To flash image and libraries, you need to run JetPack on x86_64 Ubuntu.
For DIGITs, it’s required cuDNNv6 which is only available on desktop GPU currently.
Usually, we expect user has a desktop GPU(or GPUs) and an embedded platform.
- Train with DIGITs on the desktop GPU(s)
- Inference with TensorRT on Jetson
https://developer.nvidia.com/embedded/twodaystoademo
By the way, the storage size of tx2 is much small than 100GB.
Hi, Without a desktop powered with Ubuntu x86_64 you wouldnt be able to start Jetson [In General]
For the storage you could either add 120gb ssd or mount somewhat sshfs[I used to train on a dataset ~1GB attached via sshfs] or iSCSI. [0]
2: Tensorflow works fine as it turned out to me. Do not forget to create a swap file using it![1]
1: For the DIGITs you could try employ cloud GPU instances if you have no GPU powered Desktops
0: If you just want to test what it works like you could test it with the demo jetson-interface [2]
References:
[2][url]https://github.com/dusty-nv/jetson-inference[/url]
[1][url]https://www.tensorflow.org/tutorials/image_retraining[/url]
[0][url]https://devtalk.nvidia.com/default/topic/1013970/jetson-tx2/disk-drive-extension-finding/post/5167005/#5167005[/url]
[-][url]https://devtalk.nvidia.com/default/topic/1005800/is-it-possible-to-run-tensorflow-on-tx2-/[/url]
