I am installing the pytorch 1.7, in the verification step, I encounter the problem showed in the picture. could you give me the solution, I am looking forward to your help. Thank you very much.
Hi @924971015, which version of JetPack-L4T are you running?
You should install a version of the PyTorch wheels that is compatible with the version of JetPack that you are using. You can find them in this list:
Thanks for your reply, My version of Jetpack is 4.4.1, so I should install the pytorch 1.7, but I do not know why the problem occured when verify it. Is there any other solution, I am looking forward to your reply, thank you very much.
I have solved this problem, thank you very much.
