I’m having trouble getting TensorRT to be recognized on my Jetson device and was hoping someone could offer some insight.
My Current Setup:
- JetPack: 5.1
- CUDA: 11.4.315
- cuDNN: 8.6.0.166
- OpenCV: 4.5 (compiled with CUDA support)
I attempted several different installation methods for TensorRT. I tried installing via the tar files and the deb packages, but I’m not completely sure if I did it correctly. In addition, when I run the following command:
sudo pip install tensorrt
the output shows it as being “already satisfied” (installed in /usr/lib/python3.8/dist-packages), and when I check the version using:
python3 -c "import tensorrt as trt; print(trt.__version__)"
I get the output: 8.5.2.2. However, when I inspect my system with jtop, it still seems to indicate that TensorRT is missing.
What is the correct procedure for installing TensorRT on a Jetson running JetPack 5.1?
Why does jtop not recognize TensorRT even though the Python check returns version 8.5.2.2?
Do I need to recompile OpenCV after installing TensorRT?
I would appreciate any help to resolve
