Installing TensorRT on Orin NX without docker
Hey,
have been trying to install tensorrt on the new Orin NX 16 GB. I am using Jetpack 5.1. Although the jetpack comes with the tensorrt libraries and can be installed using those, i am unable to install it’s Python APIs.
Jetpack: 5.1 which includes CUDA 11.4, TensorRT 8.5.2, cuDNN 8.6.0 and VPI 2.2
Python: 3.8
Running this in a conda env. Can share the environment.yml file to recreate the env.
Steps To Reproduce
Started with: $ pip install tensorrt_libs
Preparing metadata (setup.py) … error
error: subprocess-exited-with-error
× python setup.py egg_info did not run successfully.
│ exit code: 1
╰─> [16 lines of output]
File “”, line 2, in
File “”, line 34, in
File “/tmp/pip-install-0vapn2ox/tensorrt-libs_3fc61b4addab4290925137477c5d20f8/setup.py”, line 137, in
raise RuntimeError(open(“ERROR.txt”, “r”).read())
RuntimeError:
The package you are trying to install is only a placeholder project on PyPI.org repository.
This package is hosted on NVIDIA Python Package Index.
  This package can be installed as:
  $ pip install --extra-index-url https://pypi.nvidia.com tensorrt-libs
  [end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
In trying to figure out, tried:
  1. pip install python3-libnvinfer
raised error->
"ERROR: Could not find a version that satisfies the requirement python3-libnvinfer (from versions: none)
ERROR: No matching distribution found for python3-libnvinfer
2. Got to know that, some packages are typically provided through the NVIDIA package manager, which is specific to the JetPack version.
Tried: Adding the NVIDIA Repo key using the command,
wget https://developer.download.nvidia.com/embedded/L4T/r32_Release_v6.1/jetson-ota-public.asc
got the error->
"Connecting to developer.download.nvidia.com (developer.download.nvidia.com)|152.199.39.144|:443… connected.
HTTP request sent, awaiting response… 404 Not Found
2023-06-21 15:24:12 ERROR 404: Not Found.
Let me know if these steps are correct, or if i need to correct some command. I am still stuck in this, so any help would be great. Also, let me know if you guys need any additional data.
We are moving this post to the Jetson Orin NX forum to get better help.
Thank you.
Yes, you should just be able to do sudo apt-get install python3-libnvinfer-dev to install the TensorRT Python bindings from JetPack. These JetPack apt repos should already be active on your device after it’s flashed with SDK Manager.
Try this URL instead: https://repo.download.nvidia.com/jetson/jetson-ota-public.asc
You should have an /etc/apt/sources.list.d/nvidia-l4t-apt-source.list file that looks like this for JetPack 5.1 (L4T R35.2.1)
deb https://repo.download.nvidia.com/jetson/common r35.2 main
deb https://repo.download.nvidia.com/jetson/t234 r35.2 main
or like this for JetPack 5.1.1 (L4T R35.3.1)
deb https://repo.download.nvidia.com/jetson/common r35.3 main
deb https://repo.download.nvidia.com/jetson/t234 r35.3 main
If /etc/apt/sources.list.d/nvidia-l4t-apt-source.list doesn’t exist for you, try creating it from the above. Then you should be able to run sudo apt-get update and list/install the NVIDIA JetPack packages.
