I am using MacOS 10.5.3, and I plan to install CUDA but failed. I am really appreciate any help here.
What I did is:
1). Install CUDA Toolkit
2). Reboot
3). Set up system variable:
export PATH=/usr/local/cuda/bin:$PATH
export DYLD_LIBRARY_PATH=/usr/local/cuda/lib:$DYLD_LIBRARY_PATH
4). Create an empty folder on my desktop, unpack CUDA SDK there, and enter the folder, type “make”.
I got error at step 4. Here is the error message:
q - obj/release/bank_checker.cpp_o
q - obj/release/cmd_arg_reader.cpp_o
q - obj/release/cutil.cpp_o
q - obj/release/stopwatch.cpp_o
q - obj/release/stopwatch_linux.cpp_o
q - obj/release/multithreading.cpp_o
q - obj/release/paramgl.cpp_o
q - obj/release/param.cpp_o
make -C projects/alignedTypes/
/usr/bin/ld: /usr/local/cuda/lib/libcuda.dylib load command 7 unknown cmd field
/usr/bin/ld: /usr/local/cuda/lib/libcudart.dylib load command 7 unknown cmd field
/usr/bin/ld: /System/Library/Frameworks/OpenGL.framework/Libraries/libGL.dylib load command 7 unknown cmd field
/usr/bin/ld: /System/Library/Frameworks/OpenGL.framework/Libraries/libGLU.dylib load command 7 unknown cmd field
/usr/bin/ld: /usr/lib/gcc/i686-apple-darwin8/4.0.1/libstdc++.dylib load command 8 unknown cmd field
/usr/bin/ld: /usr/lib/gcc/i686-apple-darwin8/4.0.1/…/…/…/libSystem.dylib unknown flags (type) of section 6 (__TEXT,__literal16) in load command 0
/usr/bin/ld: /usr/lib/libSystem.B.dylib unknown flags (type) of section 6 (__TEXT,__literal16) in load command 0
collect2: ld returned 1 exit status
make[1]: *** […/…/bin/macosx/release/alignedTypes] Error 1
make: *** [projects/alignedTypes/Makefile.ph_build] Error 2
