Uninstalled previous CUDA versions using
[codebox]sudo kextunload /System/Library/Extensions/CUDA.kext
cd /Library/Frameworks/
sudo rm -rf CUDA.framework
cd /System/Library/Extensions/
sudo rm -rf CUDA.kext
cd /Library/LaunchAgents/
sudo rm -rf com.nvidia.CUDASoftwareUpdate.plist
cd /Library/PreferencePanes/
sudo rm -rf “CUDA Preferences.prefPane/”
cd /System/Library/StartupItems/
sudo rm -rf CUDA
cd /usr/local/
sudo rm -rf cuda[/codebox]
Installed the CUDA 3.1 toolkit followed by CUDA3.1.10 driver and then SDK as per [post=“0”]CUDA 3.1 release notes[/post]
GCC version is
[codebox]$ gcc -v
Using built-in specs.
Target: i686-apple-darwin10
Configured with: /var/tmp/gcc/gcc-5664~38/src/configure --disable-checking --enable-werror --prefix=/usr --mandir=/usr/share/man --enable-languages=c,objc,c++,obj-c++ --program-transform-name=/^[cg][^.-]*/s//-4.2/ --with-slibdir=/usr/lib --build=i686-apple-darwin10 --with-gxx-include-dir=/usr/include/c++/4.2.1 --host=i686-apple-darwin10 --target=i686-apple-darwin10
Thread model: posix
gcc version 4.2.1 (Apple Inc. build 5664)[/codebox]
SDK path compilation looks like this:
[codebox]$ make emu=1
a - obj/i386/release/bank_checker.cpp.o
a - obj/i386/release/cmd_arg_reader.cpp.o
a - obj/i386/release/cutil.cpp.o
a - obj/i386/release/stopwatch.cpp.o
a - obj/i386/release/stopwatch_linux.cpp.o
a - obj/i386/release/multithreading.cpp.o
a - obj/i386/release/paramgl.cpp.o
a - obj/i386/release/param.cpp.o
a - obj/i386/release/rendercheck_gl.cpp.o
src/shrUtils.cpp: In function ‘int shrLogV(int, int, const char*, char*)’:
src/shrUtils.cpp:399: warning: format not a string literal and no format arguments
src/shrUtils.cpp:403: warning: format not a string literal and no format arguments
src/shrUtils.cpp:406: warning: format not a string literal and no format arguments
./…/shared//inc/shrUtils.h: At global scope:
./…/shared//inc/shrUtils.h:55: warning: ‘nGpuArchCoresPerSM’ defined but not used
a - obj/i386/release/shrUtils.cpp.o
a - obj/i386/release/rendercheckGL.cpp.o
make -C src/alignedTypes/
sh: /usr/local/cuda/bin/…/open64/bin/nvopencc: Bad CPU type in executable
make[1]: *** [obj/i386/emurelease/alignedTypes.cu.o] Error 126
make: *** [src/alignedTypes/Makefile.ph_build] Error 2
[/codebox]
Also, I have the correct paths in my .profile
[codebox]export PATH=/usr/local/cuda/bin:/usr/texbin:/opt/local/bin:/opt/local/sbin:/opt/local/include:$PATH
export DYLD_LIBRARY_PATH=/usr/local/cuda/lib:/usr/local/lib:$DYLD_LIBRARY_PATH[/codebox]
Any suggestions?? Does everyone have this issue with 3.1?? Should I downgrade to 3.0??
Thanks in advance
