I’m working with a jetson nano which had python2.6 and 3.6 preinstalled. I installed python3.7 through sudo apt install python3.7-dev
When I tried to run the pip command, it said there was no such command. So I installed pip and pip 3 through:
sudo apt update
sudo apt install python3-pip
Output:
pip 9.0.1 from /usr/lib/python3/dist-packages (python 3.7)
So it worked fine. But pip3 and pip stopped working after I downloaded the python dependencies to install mxnet via:
sudo apt-get update
sudo apt-get install -y \
build-essential \
git \
libopenblas-dev \
libopencv-dev \
python3-pip \
python-numpy
sudo pip3 install --upgrade \
pip \
setuptools \
numpy
It says that ‘-bash: /usr/bin/pip3: No such file or directory’
I’m not really sure what went wrong. Even when I retry to install pip or pip3 the same error comes out.
