Installing Doca on Bluefield DPU
Hi all,
I’m trying to redo instructions to upgrade to doca v1.1
When trying to install Doca on Bluefield DPU, my bluefield does not have network access, I have setup the firewall, but still unable to do " apt-get update", do I have to change the mode to separated mode?
Because in Bluefield 1 we had the same issue and were not able to fix proxy setting in the embedded mode
Ideally the oob_net0 would be connected into a separate out of band management network. But in embedded mode, you can still configure an interface on the DPU and assign and IP address and route to go out through the OVS bridges for network access.
Thanks @jubetz , can you please clarify how to set OVS bridges for network access? the problem I have is that I don’t see p2p1 p2p2 interfaces in the document, what are these interfaces that we need to assign IP addresses?
Here are the interfaces I see on my first Bluefield2 card, is p2p1 equal to p0 and p2p2 equal to p1?:
root@localhost:~# ifconfig
en3f0pf0sf0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether d2:48:c6:80:c0:ec txqueuelen 1000 (Ethernet)
RX packets 61 bytes 15582 (15.5 KB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 4711 bytes 738442 (738.4 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
en3f1pf1sf0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether 8e:88:f4:78:8a:0d txqueuelen 1000 (Ethernet)
RX packets 63 bytes 15762 (15.7 KB)
TX packets 4704 bytes 737784 (737.7 KB)
enp3s0f0s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::d:58ff:fe0b:1f67 prefixlen 64 scopeid 0x20
ether 02:0d:58:0b:1f:67 txqueuelen 1000 (Ethernet)
RX packets 2134 bytes 564336 (564.3 KB)
TX packets 61 bytes 15582 (15.5 KB)
enp3s0f1s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::73:e3ff:fe80:e0b prefixlen 64 scopeid 0x20
ether 02:73:e3:80:0e:0b txqueuelen 1000 (Ethernet)
RX packets 2132 bytes 563652 (563.6 KB)
TX packets 63 bytes 15762 (15.7 KB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1000 (Local Loopback)
RX packets 2457 bytes 194358 (194.3 KB)
TX packets 2457 bytes 194358 (194.3 KB)
oob_net0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether b8:ce:f6:a8:83:04 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
p0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::bace:f6ff:fea8:82fe prefixlen 64 scopeid 0x20
ether b8:ce:f6:a8:82:fe txqueuelen 1000 (Ethernet)
RX packets 6140 bytes 932569 (932.5 KB)
RX errors 0 dropped 4 overruns 0 frame 0
TX packets 171 bytes 24267 (24.2 KB)
p1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::bace:f6ff:fea8:82ff prefixlen 64 scopeid 0x20
ether b8:ce:f6:a8:82:ff txqueuelen 1000 (Ethernet)
RX packets 6136 bytes 932141 (932.1 KB)
RX errors 0 dropped 1 overruns 0 frame 0
TX packets 173 bytes 24475 (24.4 KB)
pf0hpf: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::e408:bff:fed4:3ce4 prefixlen 64 scopeid 0x20
ether e6:08:0b:d4:3c:e4 txqueuelen 1000 (Ethernet)
TX packets 4641 bytes 733296 (733.2 KB)
pf1hpf: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::2c61:10ff:fef5:5fd0 prefixlen 64 scopeid 0x20
ether 2e:61:10:f5:5f:d0 txqueuelen 1000 (Ethernet)
TX packets 4640 bytes 733232 (733.2 KB)
tmfifo_net0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.100.2 netmask 255.255.255.252 broadcast 192.168.100.3
inet6 fe80::21a:caff:feff:ff01 prefixlen 64 scopeid 0x20
ether 00:1a:ca:ff:ff:01 txqueuelen 1000 (Ethernet)
RX packets 8891 bytes 726002 (726.0 KB)
TX packets 7704 bytes 857035 (857.0 KB)
Here is the ovs bridges:
ovs-vsctl show
31d2a29e-d043-4f8b-94d0-5dd4d47198d7
Bridge ovsbr2
Port p1
Interface p1
Port pf1hpf
Interface pf1hpf
Port ovsbr2
Interface ovsbr2
type: internal
Port en3f1pf1sf0
Interface en3f1pf1sf0
Bridge ovsbr1
Port p0
Interface p0
Port ovsbr1
Interface ovsbr1
type: internal
Port en3f0pf0sf0
Interface en3f0pf0sf0
Port pf0hpf
Interface pf0hpf
ovs_version: “2.14.1”
