Heyy all,
I need help in installing few libraries on jetson nano dev kit
matplotlib
scipy
h5py
PIL
How to do this?
Heyy all,
matplotlib
scipy
h5py
PIL
How to do this?
Quick and easy
Python2: sudo apt-get install python-scipy python-h5py python-pil
Python3: sudo apt-get install python3-scipy python3-h5py python3-pil
but depending on your use-case that may leave you with outdated versions.
For something fancier, e.g. with a Python-Environment you can:
pip install scipy h5py PIL
Thanks a lot Dominik @dkreutz .
I have few doubts which is better to use in jetson nano ?
python inbuilt package management system pip or system-wide via a package manager such as apt-get or dnf.
If i want to use a pip how to install this virtual environment and later how to access it for running various python codes on Jupyter
The apt-packages are easier way, but often they are outdated versions. Many applications require specific versions, probably conflicting with another application, so i would recommend virtual environment.
Regarding virtual environment simply do a internet search for „python venv“
