I previously installed Jetson Linux using a microSD card and it worked; however, needing more storage space, I bought an NVMe drive (Kingston NV3 1TB). I followed the instructions at Quick Start Guide — Jetson Orin Nano Developer Kit - User Guide, but it didn’t work; despite numerous attempts, it still fails to run. I prepared a USB stick using the ISO jetsoninstaller-r39.2.1-2026-08-07-18-30-47-arm64.iso. Before the firmware update, the screen displayed “Jetson System Firmware version 36.4.7-gcid-42132812 date 2025-09-18T22:10:05+00:00”; after the update, it shows “t23x_general System firmware version 39.2.1-gcid-46758480 date 2026-08-07T04:48:32+00:00”. The Jetson Linux installation proceeds normally and the system reboots at the end, but it always boots into the Shell option instead of running Linux. I have tried formatting the NVMe drive (NTFS) multiple times, but it still doesn’t work. I would appreciate some help, as I am spending a lot of time on this initial setup. Thank you in advance for your assistance.
I think we can try initrd flashing to install Jetson Linux r39.2.1 onto your NVMe SSD.
Reference: Using initrd Flash with Orin NX and Nano.
Please confirm:
- Are you using the NVIDIA Jetson Orin Nano Developer Kit or a third-party carrier board?
- Do you have an Ubuntu x86_64 host PC available? If so, which Ubuntu version?
Reflashing will erase the target NVMe data, so please back up any files you need to keep.
Hi Wichiu,
I hope you are doing well.
To answer your questions:
Yes, Serial Number: 1423725602114
No, I only have Windows 11 (x64). I do have a flash drive created with the ubuntu-26.04.1-desktop-amd64.iso image that I can use for testing. It might work.
Before reflashing, could you try checking the boot selection?
Power off the Jetson and remove the installer USB drive and microSD card, leaving the NVMe installed.
Power it on and press Esc during the NVIDIA splash screen.
Open Boot Manager and select the entry associated with the NVMe installation, if available.
If it boots successfully, make that entry the first option in the UEFI boot order.
NVIDIA’s instructions mention selecting the flashed storage from the UEFI menu. If no NVMe boot entry appears, please share a photo of the available entries.
If initrd flashing is still needed, I would use Ubuntu 22.04 x86_64 on your PC, which is listed in the r39.2.1 Quick Start requirements. I would avoid starting with Ubuntu 26.04.1 for this troubleshooting attempt. A live USB may be an option, but you will need sufficient writable Linux storage for the extracted BSP and filesystem.
RidgeRun has a walkthrough explaining the Orin Nano command-line flashing process, recovery mode, and NVMe installation:
RidgeRun — Flashing the Orin Nano from the command line
That guide targets JetPack 5.x, so use it for background and follow NVIDIA’s version-specific instructions for your installation:
NVIDIA — Using initrd Flash with Orin NX and Nano, r39.2.1
The general sequence is to prepare the r39.2.1 BSP and matching sample root filesystem on the Ubuntu host, connect the Jetson through its recovery USB-C port, enter Force Recovery Mode, verify detection with lsusb, and run the documented NVMe flashing procedure.
There is no need to format the NVMe as NTFS beforehand; flashing writes the required partition layout and filesystem. Back up anything important first, since this process erases the target storage.
Tobias Fonseca
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
If you have any saved logs or error-screen photos from the ISO installation and subsequent boot into the UEFI Shell, please share them.
Since you are using Windows 11, please try the Windows version of NVIDIA SDK Manager if possible.
Select JetPack 7.2.1 (L4T r39.2.1) and Direct Flash. Before flashing, confirm that SDK Manager detects your Orin Nano in Force Recovery Mode and offers NVMe as the target storage. If these options are unavailable, please share a screenshot of the selection screen.
Follow the SDK Manager flashing guide. Reflashing erases the target NVMe data, so please back up any files you need to keep.
If the attempt fails:
- Flashing fails: Use SDK Manager’s Export Debug Logs option and attach the ZIP file.
- Flashing completes but Linux does not boot: Please attach the complete UART boot log, captured from power-on through the failure, as a text file.
Hi Wichiu,
I will try your suggestions and inform in the sequ
ence. But there is no logs or photo about the instalation. In the true the instalation did not show any error message, the problem is that after reboot the Linux do not open, like you can see above the seqence of boot have the NVMe like the first option.
Could you please try the sdk manager and set the storage device to NVMe.
I highly suggest using the l4t_initrd_flash script to flash Jetson. When I had issues where my Orin immediately went to shell instead of even trying to boot, it was because of incorrect QSPI settings from flashing. You can even use WSL with the flash script although make sure you use Ubuntu 24.04 at the latest, because it requires qemu-user-static and that specific package isn’t available with 26. Even though later versions of QEMU work with the same commands, the script checks specifically for qemu-user-static. But if you make USB boot drive with Ubuntu 24.04 or earlier, then you could also just run SDK Manager from there. There must’ve been a new release of SDK Manager for Windows that allowed direct flashing because just three weeks ago, if you used SDK Manager on Windows, it was just for SD card or ISO flashing.
For simple usage, it’s real easy and straightforward flashing with the script. After downloading and extracting the two main packages (Driver Package and Sample Root File System), you just have to run five commands, two of which just setup the binaries, the next two creates the images, the last one flashes the images.
Please refer UEFI Adaptation — NVIDIA Jetson Linux Developer Guide to change the boot order.
I would like to thank everyone who contributed to helping me. I managed to resolve the issue after several attempts. I had initially installed the most recent version available at the time (26.04 LTS), but then tried installing version 24.04 LTS; however, the same problem persisted—it would not boot from the NVMe drive. With the help of Claude, I was able to identify a setting in the configuration menu—under Device Manager → NVIDIA Configuration → L4T Configuration—where the “OS Chain A Status” parameter needed to be changed from “Unbootable” to “Normal.” That is what allowed the system to boot from the NVMe drive. I must admit that I later wanted to switch from version 24.04 to 26.04, but I wasn’t able to; since I had alr
eady spent so much time on this, I decided to stick with 24.04. That said, I believe version 26.04 would likely work as well. If I decide to perform this upgrade in the future, I will let you know.
I forgot to mention that whenever you change configuration parameters (even when using F10), you must select the “Reset” option on the initial screen to ensure the changes are actually applied. I read this tip on a forum, and it really worked for me—it resolved some strange behaviors I had been noticing.
